Does anyone know how to add encryption to a vcd? I have some personal videos i dont want my room mate copying can anyone help
With the ability to use tools like CloneCD et al, to burn a 1:1 copy and then work on cracking it at their leisure, it'd be mighty hard to do. Get a sturdy box and lock them up, or get rid of the roommate that isn't trustworthy. If they are that "your eyes only" keep them off-site in a secure location.Originally Posted by bay_area_415
As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war." -
Exactly!
Adding "encryption" to a VCD is not possible in the same way it isn't possible to add "encryption" to VHS. Anything robust you do to the VCD that makes it copy-protected also probably make it unreadable on VCD/DVD players.
Regards.Michael Tam
w: Morsels of Evidence
AACS Bluray encryption
By BIFFtheSTIFF in forum MacReplies: 0Last Post: 17th Jun 2011, 21:26 -
Does GI Joe: Rise of the Cobra use a new encryption...
By rayden54 in forum Newbie / General discussionsReplies: 6Last Post: 2nd Apr 2010, 10:45 -
Is WPA encryption really better than WEP?
By yoda313 in forum ComputerReplies: 34Last Post: 25th Oct 2009, 22:14 -
Best encryption algorithm?
By alegator in forum ComputerReplies: 5Last Post: 10th May 2009, 23:37 -
BD+ encryption blue-ray
By herbapou in forum Blu-ray RippingReplies: 4Last Post: 24th Mar 2009, 07:58
