Hi,
I can play the TV on my screen, but when I hit the record button, the software locks up. I can clear it by terminating the software, but it won't record. All the tests I could find seem to pass, so I'm not sure what's up. I've tried a couple other programs and they've had problems too. The included ULead software bogged down to the point of almost locking up, and another one (Video Wave III I think) complained that it wasn't getting time stamps and refused to record anything.
I've tried reseating the card a few times and reinstalling everything a few times. ATI hasn't responded yet of course. Any thoughts? Is it broken?
Brian
What resolution are you capturing? If its 480x480, 640x480, or 720x480 MMC 7.1 will freeze when you attempt to begin your capture. Try capturing at 352x480 and see if it solves your problem. If you want to use the resolutions mentioned above simply to a capture for a few seconds using the standard VCD setting, you don't have to save the resulting file. Then switch to your 480x480 resolution or any of the others.
Capture problem with ATI Radeon HD 2900 XT in Wondows XP SP2
By redrock1 in forum Capturing and VCRReplies: 3Last Post: 21st Mar 2008, 01:03 -
ATI 7500 AIW capture problems
By saoneg in forum Capturing and VCRReplies: 8Last Post: 6th Mar 2008, 05:11 -
ATI AIW X800GT - ANY capture software besides MMC?
By nbarzgar in forum Capturing and VCRReplies: 23Last Post: 18th Nov 2007, 01:24 -
Premiere Crashes on 720 P 25 capture
By Dejablues in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 25th Oct 2007, 10:14 -
Anyone using MMC with X800XL VIVO-only (no TV tuner or AIW) for capture?
By palouse in forum Capturing and VCRReplies: 4Last Post: 15th Aug 2007, 02:28
