Results 1 to 13 of 13
  1. I try to extract the cdm and when I extract it I check the folder that was created with the name of my device and I find the cdm but I see that it only weighs 1 kb and not 2 kb which I don't know why this error happens.
    Try this page to extract the cdm: https://bitmovin.com/demos/drm
    And I also tried with some platforms and all of them extracted the file weighing only 1 kb.
  2. Don't worry about filesize provided you got the right files. What are the names of your files?
    From what I have seen they will range from anywhere 1-1.8kb
  3. Originally Posted by BeLive View Post
    The names of the files are 4445.bin and 4445.json, but I already tried putting them inside wks-keys and when I try the l3.py command entering pssh and license it gives an error and I suppose that is why it is not extracting the file very well cdm the dumper.
  4. It seems it wasn't successful otherwise you would have gotten files like .bin and .pem for client_id and private_key respectfully. Wait for any experts to give further guidance.
  5. Originally Posted by BeLive View Post
    ok thanks i hope someone can help me
  6. go to the bitmovin demo page
    play the content
    then refresh - the keys get dumped on refresh
  7. Originally Posted by codehound View Post
    play the content
    I already tried that and it keeps downloading only 2 files: one in .bin format and the other in .json format
  8. close the page then.
    then reopen it
  9. Originally Posted by codehound View Post
    then reopen it
    I still get the same error, it generates a .bin and a .json
  10. Originally Posted by Brift_Bv View Post
    then reopen it
    Then other issues are in force.
    Read this excellent guide, then read it again until you understand it:
    https://forum.videohelp.com/threads/404994-Decryption-and-the-Temple-of-Doom
  11. Originally Posted by codehound View Post
    then reopen it
    I just read all the information in that post and I did everything as user angela said, however I see two users who gave them the same error as me and I don't see any solution to that in that post
  12. These are other recommendations people gave over time which you can try:
    • Downgrade OS
    • If DRMinfo app is showing L1 then make sure to downgrade it to L3. You can do that renaming "liboemcrypto.so" file to something else.
  13. No need to downgrade OS!
