Hi
Im using AVS video converter to convert a largest mp4 file to DVD. To get the complete video onto one disc i have to use LP (which the conversion is quite good for LP) If you take a look at the image, you will note the output size 3.19 Gb. I was wondering, if possible. I would like to upscale the size to near to full disc size hoping to get a bit more quality. How and what software would be best to use ? ....... Thanks
[Attachment 65769 - Click to enlarge]
	Just raise the bitrate. Use a bitrate calculator to determine what it should be to fill the disc.
	The other thing I noticed on the image above, probably should be using ac/3 audio instead of mp2
	Raise the bitrate in avs video convertor till it reads 3.9 GB. I think,therefore i am a hamster.
	Thanks to everyone for the information...Much appreciated.
 johns0 wrote:I did try. I'm using the free version, i think it only works on the pay version...ThanksRaise the bitrate in avs video convertor till it reads 3.9 GB.Last edited by Dani33; 7th Jul 2022 at 13:22.
  Demux .mp4 (video+audio) to 2 separate files (video.mp4) + (audio.mp4)By kalemvar1 in forum Video ConversionReplies: 3Last Post: 15th Dec 2021, 08:05
  ffmpeg losing subtitle track converting MP4 to MP4By the_steve_randolph in forum Newbie / General discussionsReplies: 9Last Post: 31st May 2021, 17:42
  Rewrap MTS to MP4 w/o re-encoding. Why is MP4 smaller? GUI batch tool?By Razz in forum Video ConversionReplies: 7Last Post: 13th Mar 2021, 17:24
  FFMPEG Conversion from MKV to MP4 returns a empty MP4 file?By lolmaisine in forum Video ConversionReplies: 4Last Post: 6th Mar 2019, 08:45
  Split mp4 file into specified size (part1.mp4, part2.mp4 etc.)By TubeBar in forum EditingReplies: 7Last Post: 1st Feb 2019, 23:41
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
