So, just in case anyone is curious... LP seems to have held up very well for my camera (Sony TRV-720). The tape was a Maxell XR-Metal Hi-8 and it was stored on a bookshelf in my office for 21 years (Datecode is May 26, 2001). I'm using the AudioVisual Preservation Solutions DV Analyzer to look at my capture and no frames are flagged with errors or concealment. Obviously your mileage may vary, but it would appear that using the right tape and equipment, LP was less fragile than rumored. For the record, I did capture this to hard drive more than a decade ago and have had backup copies so I wasn't risking anything further by letting the tape sit on a shelf. I was just curious if I could still recapture from it w/o errors this far down the road. So likely the biggest downside to LP is that if a spot on the tape DOES flake, it'll hit more frames.
It will also depend on what you are using to play the tapes back. If the camcorder that the footage was shot on is still working and that is used, decent tapes, stored correctly, should be fine. It's more when you try to play the tapes back on a different machine that problems are likely to show up. As I have more than one camcorder, I mark the tapes to show which one they were shot on.
How can you tell Digital8 vs. HI-8?
By seanmcnally in forum Capturing and VCRReplies: 90Last Post: 12th Apr 2022, 20:17 -
very Buggy if u loose password - back after 10 years
By melani in forum FeedbackReplies: 2Last Post: 25th Jan 2022, 22:56 -
14 years and I still check back here every once in a while :)
By makntraks in forum Off topicReplies: 55Last Post: 24th Apr 2020, 20:18 -
which media is best for storing for years
By asiafan in forum Authoring (Blu-ray)Replies: 26Last Post: 12th Oct 2018, 12:14 -
I have VHS that are about 25 years old..
By Sharpr in forum RestorationReplies: 17Last Post: 17th Sep 2018, 12:41
