There's a rather nice DVD menu that I'd love to be able to keep on for a DVD that I am customising with subtitles. Just one page, 4 items, which would fit perfectly.
So... can this be done? I seem to be able to import the menu with PCGedit; only, that doesn't lead to a disc that's working properly. No doubt I need to further adjust something.
If it can be done (maybe it's already covered in existing instructions?) I'd love to hear how.![]()
In this case, vobblanker won't work because the disc I want to edit has all 4 items in one ifo set. I tried that but I am replacing one of the videos with one with a different aspect ratio. It doesn't seem a possibility to have two different ARs in this design. Or if it IS, that would also solve my question just as well.
This is nøt å signåture.™
It is possible to do everything you want but it may require more time and work than you are prepared to invest in this project.
DVDs use instructions written in a primitive programming language. You would use PCGEdit to replace the original instructions used the menu so they provide the functionality you desire for the DVD. PGCEdit has a trace function for debugging. If you already have an extensive computer programming background you can probably figure out how to change the instructions. If not, you have a long, hard road ahead of you.
To be able to use different aspect ratios for the 4 titles, each one must be in its own titleset ("IFO set"). You will need to re-author the 4 videos so that each has its own titleset.Ignore list: hello_hello, tried, TechLord, Snoopy329 -
You could also do this with dvdremakepro (I have done this a number of times), but its not freeware and in sync with usually_quiet's reply you would have to do a bit of relinking. Worse if you are not familiar with any of the commands
How to get the streaming link from a page?
By AltSurf in forum Video Streaming DownloadingReplies: 2Last Post: 7th Mar 2021, 11:03 -
Ad placement on front page seems off for me.
By gll99 in forum FeedbackReplies: 5Last Post: 21st Oct 2020, 23:43 -
How to Download Such Videos on This Page?
By devilcoelhodog in forum Video Streaming DownloadingReplies: 5Last Post: 20th Feb 2019, 22:49 -
web page coding
By vhelp in forum ProgrammingReplies: 8Last Post: 15th Feb 2019, 08:48 -
Downloading Video From This Page
By devilcoelhodog in forum Video Streaming DownloadingReplies: 6Last Post: 11th Mar 2018, 08:55
