Hello! Witch is the best way to cut some scenes from a movie ?
Results 1 to 11 of 11
Should be 'Which'. A 'Witch' is a fictitious person that rides around on a broom. But davexnet is correct.
Extraordinary claims require extraordinary evidence -Carl Sagan -
I used to use AVI demuxe, but I am looking for a new program as its user interface is very poor, and it wont allow me to skip or fast forward to various places to mark them.
Some recommendation of some good programs woud be helpful.
Not all video editors do the job well -
Don't forget, typical consumer video (avi/mp4/mkv using xvid/H.264/H.265/mpeg-2)when cut is not frame accurate, it can only be cut on
key frames, giving accuracy within about 5 - 10 seconds.
For frame accurate cuts of consumer video at any location, "smart" cuts, that can deal with this by re-encoding a few seconds at the cut point -
the rest is copied as-is, would include Tmpgenc Smart renderer and the VideoRedo TVSuite. These products offer a free trial if you're interested
Of course if you're willing to re-encode the output, you can cut anywhere -
To seek in Avidemux v2.8/2.8.1-dev (x64), click on the timeline, copy paste a timestamp in the format 00:00:00.000 with Ctrl-V in "Go > Go to Time".
To fast forward, you use the thumb slider to the right of the navigation timeline (hover over it with the mouse, you can now fast forward using the mouse wheel), or the hotkey for 60s forward/backward (button in navigation toolbar).
Some features are still missing for advanced video editing (ex: bookmarks), but it certainly can do the job for simple trimming/cutting.
Slow scenes in some parts of the video
By jab66 in forum Video ConversionReplies: 13Last Post: 8th Nov 2020, 20:55 -
Make Scenalyzer not cut into scenes
By kodec in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 12th Feb 2020, 16:21 -
Incorrect video cut timing on MKV video with lossless quality
By may5224 in forum EditingReplies: 8Last Post: 19th Nov 2019, 15:02 -
Best software to cut scenes and sometimes just mute audio?
By Dougmeister in forum EditingReplies: 6Last Post: 10th May 2019, 05:52 -
Awful video quality at dark scenes encoding x265/HEVC
By TheFunkyDude in forum Video ConversionReplies: 5Last Post: 12th Sep 2017, 20:05
