Hi, i can't decrypt this segment using mp4decrypt v 1.4
init
segmentCode:https://www.mediafire.com/file/41nm3xqujg23ory/0_1_3519_init.mp4/file
psshCode:https://www.mediafire.com/file/fx3898fehpd7cn1/0_1_3519_149131310175180.mp4/file
default_KIDCode:AAAAiHBzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAAGgIARIQWA0ccDTY6BgjdP53xHdJoBIQH7rsOV0BM3TmyyBxB90bChIQx49W2DcwfMI0bsq178WDyBIQTPw+QqeiYd3hKULfDtNe5BIQEqP6hNUWi6TrJMz14RSXARoAKgAyADgASABQAA==
keys :Code:1fbaec39-5d01-3374-e6cb-207107dd1b0a
Code:c78f56d837307cc2346ecab5efc583c8:3dfb1b1034144807b6b775a622d29b76 1fbaec395d013374e6cb207107dd1b0a:61c1807549aff34b6801be80b9e4a8e7 4cfc3e42a7a261dde12942df0ed35ee4:b89bdcca39a692caa428bc6b61064be0 12a3fa84d5168ba4eb24ccf5e1149701:a3bfe99d044aeee5f530283d7b3445f8 580d1c7034d8e8182374fe77c47749a0:9112a58d7937fd336285c91135604f27
concat init + segment using bash:
decrypt it :Code:cat 0_1_3519_init.mp4 0_1_3519_149131310175180.mp4 > segment.mp4
the stream still scrambledCode:./mp4decrypt --key 1fbaec395d013374e6cb207107dd1b0a:61c1807549aff34b6801be80b9e4a8e7 --show-progress segment output.mp4
but when i use player ex: https://bitmovin.com/demos/stream-test , the stram work !!!
mp4dump init :
mp4dump show kid 0000000000000Code:[ftyp] size=8+32 major_brand = mp41 minor_version = 0 compatible_brand = iso8 compatible_brand = isom compatible_brand = mp41 compatible_brand = dash compatible_brand = hvc1 compatible_brand = cmfc [moov] size=8+829 [mvhd] size=12+96 timescale = 90000 duration = 0 duration(ms) = 0 [trak] size=8+673 [tkhd] size=12+80, flags=7 enabled = 1 id = 1 duration = 0 width = 1920.000000 height = 1080.000000 [mdia] size=8+537 [mdhd] size=12+20 timescale = 90000 duration = 0 duration(ms) = 0 language = und [hdlr] size=12+33 handler_type = vide handler_name = VideoHandler [minf] size=8+452 [dinf] size=8+28 [dref] size=12+16 [url ] size=12+0, flags=1 location = [local to file] [stbl] size=8+388 [stsd] size=12+308 entry_count = 1 [encv] size=8+296 data_reference_index = 1 width = 1920 height = 1080 compressor = HEVC Coding [hvcC] size=8+130 Configuration Version = 1 Profile Space = 0 Profile = Main Tier = 0 Profile Compatibility = 40000000 Constraint = 0 Level = 123 Min Spatial Segmentation = 0 Parallelism Type = 0 Chroma Format = 1 Chroma Depth = 8 Luma Depth = 8 Average Frame Rate = 0 Constant Frame Rate = 0 Number Of Temporal Layers = 0 Temporal Id Nested = 0 NALU Length Size = 4 [sinf] size=8+72 [frma] size=8+4 original_format = hvc1 [schm] size=12+8 scheme_type = cenc scheme_version = 65536 [schi] size=8+32 [tenc] size=12+20 default_isProtected = 1 default_Per_Sample_IV_Size = 8 default_KID = [00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00] [stts] size=12+4 entry_count = 0 [stsc] size=12+4 entry_count = 0 [stsz] size=12+8 sample_size = 0 sample_count = 0 [stco] size=12+4 entry_count = 0 [vmhd] size=12+8, flags=1 graphics_mode = 0 op_color = 0000,0000,0000 [edts] size=8+28 [elst] size=12+16 entry_count = 1 entry/segment duration = 0 entry/media time = 3600 entry/media rate = 1 [mvex] size=8+32 [trex] size=12+20 track id = 1 default sample description index = 1 default sample duration = 0 default sample size = 0 default sample flags = 0
any ideas !!!!
thanks
Results 1 to 9 of 9
i uploaded the init and 1 segment
the mpd url is not public
Code:<?xml version="1.0" encoding="UTF-8"?> <MPD xmlns="urn:mpeg:dash:schema:mpd:2011" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="urn:mpeg:dash:schema:mpd:2011 DASH-MPD.xsd" xmlns:cenc="urn:mpeg:cenc:2013" profiles="urn:mpeg:dash:profile:isoff-live:2011" type="dynamic" publishTime="2022-07-05T13:49:27Z" availabilityStartTime="1970-01-01T00:00:00Z" minimumUpdatePeriod="PT2S" minBufferTime="PT6.4S" timeShiftBufferDepth="PT14400S" suggestedPresentationDelay="PT9.6S"> <UTCTiming schemeIdUri="urn:mpeg:dash:utc:http-iso:2014" value="https://time.akamai.com/?iso" /> <Period id="0" start="PT0S"> <AdaptationSet id="0" group="1" segmentAlignment="true" startWithSAP="1" contentType="video"> <ContentProtection schemeIdUri="urn:uuid:edef8ba9-79d6-4ace-a3c8-27dcd51d21ed"><cenc:pssh>AAAAiHBzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAAGgIARIQH7rsOV0BM3TmyyBxB90bChIQx49W2DcwfMI0bsq178WDyBIQTPw+QqeiYd3hKULfDtNe5BIQEqP6hNUWi6TrJMz14RSXARIQWA0ccDTY6BgjdP53xHdJoBoAKgAyADgASABQAA==</cenc:pssh></ContentProtection> <ContentProtection schemeIdUri="urn:mpeg:dash:mp4protection:2011" value="cenc" cenc:default_KID="4cfc3e42-a7a2-61dd-e129-42df0ed35ee4"/> <SupplementalProperty schemeIdUri="urn:mpeg:dash:adaptation-set-switching:2016" value="1,2,3"/> <Representation id="379" bandwidth="400000" codecs="avc1.64000d" mimeType="video/mp4" width="384" height="216" frameRate="25"> <SegmentTemplate timescale="90000" initialization="0_1_379_init" media="0_1_379_$Time$"> <SegmentTimeline> <S t="149131309959180" d="288000" r="4503"/> </SegmentTimeline> </SegmentTemplate> </Representation><Representation id="380" bandwidth="800000" codecs="avc1.64001e" mimeType="video/mp4" width="640" height="360" frameRate="25"> <SegmentTemplate timescale="90000" initialization="0_1_380_init" media="0_1_380_$Time$"> <SegmentTimeline> <S t="149131309959180" d="288000" r="4503"/> </SegmentTimeline> </SegmentTemplate> </Representation><Representation id="381" bandwidth="1600000" codecs="avc1.64001f" mimeType="video/mp4" width="896" height="504" frameRate="25"> <SegmentTemplate timescale="90000" initialization="0_1_381_init" media="0_1_381_$Time$"> <SegmentTimeline> <S t="149131309959180" d="288000" r="4503"/> </SegmentTimeline> </SegmentTemplate> </Representation><Representation id="3517" bandwidth="1600000" codecs="hvc1.1.2.L93" mimeType="video/mp4" width="896" height="504" frameRate="50"> <SegmentTemplate timescale="90000" initialization="0_1_3517_init" media="0_1_3517_$Time$"> <SegmentTimeline> <S t="149131310175180" d="288000" r="4502"/> </SegmentTimeline> </SegmentTemplate> </Representation> </AdaptationSet> <AdaptationSet id="1" group="1" segmentAlignment="true" startWithSAP="1" contentType="video"> <ContentProtection schemeIdUri="urn:uuid:edef8ba9-79d6-4ace-a3c8-27dcd51d21ed"><cenc:pssh>AAAAiHBzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAAGgIARIQH7rsOV0BM3TmyyBxB90bChIQx49W2DcwfMI0bsq178WDyBIQTPw+QqeiYd3hKULfDtNe5BIQEqP6hNUWi6TrJMz14RSXARIQWA0ccDTY6BgjdP53xHdJoBoAKgAyADgASABQAA==</cenc:pssh></ContentProtection> <ContentProtection schemeIdUri="urn:mpeg:dash:mp4protection:2011" value="cenc" cenc:default_KID="12a3fa84-d516-8ba4-eb24-ccf5e1149701"/> <SupplementalProperty schemeIdUri="urn:mpeg:dash:adaptation-set-switching:2016" value="0,2,3"/> <Representation id="382" bandwidth="3000000" codecs="avc1.64001f" mimeType="video/mp4" width="1280" height="720" frameRate="25"> <SegmentTemplate timescale="90000" initialization="0_1_382_init" media="0_1_382_$Time$"> <SegmentTimeline> <S t="149131309959180" d="288000" r="4503"/> </SegmentTimeline> </SegmentTemplate> </Representation> </AdaptationSet> <AdaptationSet id="2" group="1" segmentAlignment="true" startWithSAP="1" contentType="video"> <ContentProtection schemeIdUri="urn:uuid:edef8ba9-79d6-4ace-a3c8-27dcd51d21ed"><cenc:pssh>AAAAiHBzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAAGgIARIQH7rsOV0BM3TmyyBxB90bChIQx49W2DcwfMI0bsq178WDyBIQTPw+QqeiYd3hKULfDtNe5BIQEqP6hNUWi6TrJMz14RSXARIQWA0ccDTY6BgjdP53xHdJoBoAKgAyADgASABQAA==</cenc:pssh></ContentProtection> <ContentProtection schemeIdUri="urn:mpeg:dash:mp4protection:2011" value="cenc" cenc:default_KID="c78f56d8-3730-7cc2-346e-cab5efc583c8"/> <SupplementalProperty schemeIdUri="urn:mpeg:dash:adaptation-set-switching:2016" value="0,1,3"/> <Representation id="3518" bandwidth="4800000" codecs="hvc1.1.2.L123" mimeType="video/mp4" width="1920" height="1080" frameRate="50"> <SegmentTemplate timescale="90000" initialization="0_1_3518_init" media="0_1_3518_$Time$"> <SegmentTimeline> <S t="149131310175180" d="288000" r="4502"/> </SegmentTimeline> </SegmentTemplate> </Representation> </AdaptationSet> <AdaptationSet id="3" group="1" segmentAlignment="true" startWithSAP="1" contentType="video"> <ContentProtection schemeIdUri="urn:uuid:edef8ba9-79d6-4ace-a3c8-27dcd51d21ed"><cenc:pssh>AAAAiHBzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAAGgIARIQH7rsOV0BM3TmyyBxB90bChIQx49W2DcwfMI0bsq178WDyBIQTPw+QqeiYd3hKULfDtNe5BIQEqP6hNUWi6TrJMz14RSXARIQWA0ccDTY6BgjdP53xHdJoBoAKgAyADgASABQAA==</cenc:pssh></ContentProtection> <ContentProtection schemeIdUri="urn:mpeg:dash:mp4protection:2011" value="cenc" cenc:default_KID="1fbaec39-5d01-3374-e6cb-207107dd1b0a"/> <SupplementalProperty schemeIdUri="urn:mpeg:dash:adaptation-set-switching:2016" value="0,1,2"/> <Representation id="3519" bandwidth="14800000" codecs="hvc1.1.2.L123" mimeType="video/mp4" width="1920" height="1080" frameRate="50"> <SegmentTemplate timescale="90000" initialization="0_1_3519_init" media="0_1_3519_$Time$"> <SegmentTimeline> <S t="149131310175180" d="288000" r="4502"/> </SegmentTimeline> </SegmentTemplate> </Representation> </AdaptationSet> <AdaptationSet id="376" group="2" segmentAlignment="true" startWithSAP="1" contentType="audio" lang="fra"> <ContentProtection schemeIdUri="urn:uuid:edef8ba9-79d6-4ace-a3c8-27dcd51d21ed"><cenc:pssh>AAAAiHBzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAAGgIARIQH7rsOV0BM3TmyyBxB90bChIQx49W2DcwfMI0bsq178WDyBIQTPw+QqeiYd3hKULfDtNe5BIQEqP6hNUWi6TrJMz14RSXARIQWA0ccDTY6BgjdP53xHdJoBoAKgAyADgASABQAA==</cenc:pssh></ContentProtection> <ContentProtection schemeIdUri="urn:mpeg:dash:mp4protection:2011" value="cenc" cenc:default_KID="580d1c70-34d8-e818-2374-fe77c47749a0"/> <Role schemeIdUri="urn:mpeg:dash:role:2011" value="main"/> <Representation id="376" bandwidth="64000" codecs="mp4a.40.2" mimeType="audio/mp4"> <SegmentTemplate timescale="90000" initialization="0_1_376_init" media="0_1_376_$Time$"> <SegmentTimeline> <S t="149131310114096" d="288000" r="4502"/> </SegmentTimeline> </SegmentTemplate> </Representation> </AdaptationSet> <AdaptationSet id="377" group="2" segmentAlignment="true" startWithSAP="1" contentType="audio" lang="und"> <ContentProtection schemeIdUri="urn:uuid:edef8ba9-79d6-4ace-a3c8-27dcd51d21ed"><cenc:pssh>AAAAiHBzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAAGgIARIQH7rsOV0BM3TmyyBxB90bChIQx49W2DcwfMI0bsq178WDyBIQTPw+QqeiYd3hKULfDtNe5BIQEqP6hNUWi6TrJMz14RSXARIQWA0ccDTY6BgjdP53xHdJoBoAKgAyADgASABQAA==</cenc:pssh></ContentProtection> <ContentProtection schemeIdUri="urn:mpeg:dash:mp4protection:2011" value="cenc" cenc:default_KID="580d1c70-34d8-e818-2374-fe77c47749a0"/> <Role schemeIdUri="urn:mpeg:dash:role:2011" value="main"/> <Representation id="377" bandwidth="64000" codecs="mp4a.40.2" mimeType="audio/mp4"> <SegmentTemplate timescale="90000" initialization="0_1_377_init" media="0_1_377_$Time$"> <SegmentTimeline> <S t="149131310114096" d="288000" r="4502"/> </SegmentTimeline> </SegmentTemplate> </Representation> </AdaptationSet> <AdaptationSet id="455" group="3" segmentAlignment="true" startWithSAP="1" contentType="text" lang="fra"> <Role schemeIdUri="urn:mpeg:dash:role:2011" value="caption"/> <Representation id="455" bandwidth="64000" codecs="stpp" mimeType="application/mp4"> <SegmentTemplate timescale="90000" initialization="0_1_455_init" media="0_1_455_$Time$"> <SegmentTimeline> <S t="149131310112000" d="288000" r="4502"/> </SegmentTimeline> </SegmentTemplate> </Representation> </AdaptationSet> <AdaptationSet id="461" group="3" segmentAlignment="true" startWithSAP="1" contentType="text" lang="fra"> <Role schemeIdUri="urn:mpeg:dash:role:2011" value="subtitle"/> <Representation id="461" bandwidth="64000" codecs="stpp" mimeType="application/mp4"> <SegmentTemplate timescale="90000" initialization="0_1_461_init" media="0_1_461_$Time$"> <SegmentTimeline> <S t="149131310112000" d="288000" r="4502"/> </SegmentTimeline> </SegmentTemplate> </Representation> </AdaptationSet> <AdaptationSet id="463" group="2" segmentAlignment="true" startWithSAP="1" contentType="audio" lang="fra"> <ContentProtection schemeIdUri="urn:uuid:edef8ba9-79d6-4ace-a3c8-27dcd51d21ed"><cenc:pssh>AAAAiHBzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAAGgIARIQH7rsOV0BM3TmyyBxB90bChIQx49W2DcwfMI0bsq178WDyBIQTPw+QqeiYd3hKULfDtNe5BIQEqP6hNUWi6TrJMz14RSXARIQWA0ccDTY6BgjdP53xHdJoBoAKgAyADgASABQAA==</cenc:pssh></ContentProtection> <ContentProtection schemeIdUri="urn:mpeg:dash:mp4protection:2011" value="cenc" cenc:default_KID="580d1c70-34d8-e818-2374-fe77c47749a0"/> <Role schemeIdUri="urn:mpeg:dash:role:2011" value="description"/> <Representation id="463" bandwidth="64000" codecs="mp4a.40.2" mimeType="audio/mp4"> <SegmentTemplate timescale="90000" initialization="0_1_463_init" media="0_1_463_$Time$"> <SegmentTimeline> <S t="149131310114096" d="288000" r="4502"/> </SegmentTimeline> </SegmentTemplate> </Representation> </AdaptationSet> </Period> </MPD>
mediainfo:
General
Complete name : 0_1_3519_init.mp4
Format : MPEG-4
Format profile : Base Media / Version 1
Codec ID : mp41 (iso8/isom/mp41/dash/hvc1/cmfc)
File size : 877 Bytes
Encoded date : UTC 2022-07-05 02:01:10
Tagged date : UTC 2022-07-05 02:01:10
Video
Format : HEVC
Format/Info : High Efficiency Video Coding
Format profile : Main@L4.1@Main
Codec ID : encv / hvc1
Codec ID/Info : High Efficiency Video Coding
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 50.000 FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Encryption : Encrypted
Codec configuration box : hvcC -
This is live dynamic mpd
Segments are too small to play
What exactly did you expect to play from 877 Bytes?discord=notaghost9997
Playing DRM protected video using keys.
By dark125 in forum Video Streaming DownloadingReplies: 8Last Post: 22nd Dec 2025, 14:24 -
circumventing DRM or hacking encryption keys
By sum_guy in forum FeedbackReplies: 10Last Post: 5th Aug 2024, 04:57 -
decrypt video using keys from txt file
By m0ck in forum Video Streaming DownloadingReplies: 13Last Post: 14th Feb 2023, 11:03 -
How can I found the keys of a specific website DRM WindVine
By $_$ in forum Video Streaming DownloadingReplies: 1Last Post: 30th May 2021, 03:04 -
Download DRM protected video and decrypt it with a drm licence url
By vikral in forum Video Streaming DownloadingReplies: 9Last Post: 9th Feb 2021, 03:14
