I used to download MP4 files, a lot of them. I was not doing for quilte a long time.
I always found great video quality in mp4 and play them from USB port of 3d supportin TV.
Some time when I played 3D videos I always missed the 5.1 surrounds. I remember until 2018 I was able to find no way other than to play a 5.1 DVD .
Now recently I notice many mp4 files are mentioned with (5.1)!
Will they work If I play them on my theatre USB. I do have port! however I wonder if old DVD thaters by Samsung purchased 8-9 years from now, will be able to recognize the 5.1 AC3 sound?
Anyone have any such experience?
Try playing some mp4 files with 5.1-channel AC3 audio and find out for yourself. If the files don't play with 5.1 sound then you'll have your answer. Performing this little experiment can't damage your equipment.
Ignore list: hello_hello, tried, TechLord, Snoopy329 -
You can do experiment as advised by usually_quiet or check is there Dolby Digital logo on your equipment... If Dolby logo is present then on 99.99% cases everything should work correct.
A model number of the Samsung DVD theater would be useful to determine what it is capable of playing.
For myself I use a USB port in my BD player.( It is an LG manufactured in 2012 & has no Cinavia detection)
The Display function of the BD player shows the Audio being played.
Further so does my Denon receiver that the Audio is played through.
mp4 files - audio out of sync
By pandalina in forum EditingReplies: 9Last Post: 8th Feb 2022, 12:59 -
Demux .mp4 (video+audio) to 2 separate files (video.mp4) + (audio.mp4)
By kalemvar1 in forum Video ConversionReplies: 3Last Post: 15th Dec 2021, 07:05 -
Batch combining multiple audio files with same picture to create mp4 files
By MD_89 in forum AudioReplies: 25Last Post: 1st Dec 2018, 22:29 -
convert AC3 audio in my MP4 videos to AAC
By njitgrad in forum AudioReplies: 13Last Post: 4th Feb 2018, 16:08 -
Help ... audio and video files to MP4 or ????
By xtal_01 in forum Newbie / General discussionsReplies: 6Last Post: 16th Dec 2017, 08:08
