  1. Hi all!
    I've rendered animated objects on a google earth streetview (13312x6656) and exported it as a mp4 video. I can play it with 1920x960 resolution, but when exporting the video in original resolution, none of my applications will play it.
    I wish to keep the original resolution or similar, because i intend to view the video with vr glasses.
    I tried vlc, windows player etc.
    My computer spec:
    Device name MSI
    Processor Intel(R) Core(TM) i7-9750H CPU @ 2.60GHz 2.60 GHz
    Installed RAM 16.0 GB (15.8 GB usable)
    Device ID D921AD11-092A-479B-914B-4A49A70BE1E0
    Product ID 00325-81471-35575-AAOEM
    System type 64-bit operating system, x64-based processor
    Edition Windows 10 Home
    Version 21H2
    Installed on ‎3/‎22/‎2021
    OS build 19044.1766
    Experience Windows Feature Experience Pack 120.2212.4180.0
    Kind regards
    eeast
  2. I tried several players with Win10: Windows Media Player, MPCHC, MPCBE, VLC, PotPlayer, KMPlayer, and SMPlayer. The only one that would play a video of that frame size properly was SMPlayer. Some of the others might work if you disable hardware decoding or switch output devices.
