Hi there,
I had downloaded the fragments from
it is an ended mpeg-dash stream, and I found the wv keys isCode:https://bcovlive-a.akamaihd.net/664b4abdb2634e14b39426e5f836747b/ap-northeast-1/6160987587001/playlist_wv.m3u8
So, what I had done is merged the fragments with the init file in CMD byCode:b35ba32acf43e2865cb0771219af08d5:989d4b0938b6902471a10d77c0db753b
and then I used mp4decrypt to decrypt the merged fragmentsCode:copy /B init.mp4+4900.m4s+4901.m4s+4902.m4s enc.mp4
the MPC player is able to open the video file, however, it cannot start to play, there is black and no audio.Code:mp4decrypt --key b35ba32acf43e2865cb0771219af08d5:989d4b0938b6902471a10d77c0db753b enc.mp4 dec.mp4
Does anyone know what I have missed?
Thanks.
edit: I see your command after I submit this reply, thanks I am able to merge it now
do you mean concatenate the media fragments (m4s)? can you teach me the command?
i wrote the list.txt
and run with command:Code:file 'c:\test\0000.mp4' file 'c:\test\738.m4s' file 'c:\test\739.m4s' file 'c:\test\740.m4s'
ffmpeg returns errorCode:ffmpeg -f concat -safe 0 -i list.txt target.mp4
the files is not the same with the stream I provided at top but is download from same stream provider and ffmpeg returns similar error messageCode:ffmpeg version 5.0.1-full_build-www.gyan.dev Copyright (c) 2000-2022 the FFmpeg developers built with gcc 11.2.0 (Rev7, Built by MSYS2 project) configuration: --enable-gpl --enable-version3 --enable-static --disable-w32threads --disable-autodetect --enable-fontconfig --enable-iconv --enable-gnutls --enable-libxml2 --enable-gmp --enable-bzlib --enable-lzma --enable-libsnappy --enable-zlib --enable-librist --enable-libsrt --enable-libssh --enable-libzmq --enable-avisynth --enable-libbluray --enable-libcaca --enable-sdl2 --enable-libdav1d --enable-libdavs2 --enable-libuavs3d --enable-libzvbi --enable-librav1e --enable-libsvtav1 --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxavs2 --enable-libxvid --enable-libaom --enable-libopenjpeg --enable-libvpx --enable-mediafoundation --enable-libass --enable-frei0r --enable-libfreetype --enable-libfribidi --enable-liblensfun --enable-libvidstab --enable-libvmaf --enable-libzimg --enable-amf --enable-cuda-llvm --enable-cuvid --enable-ffnvcodec --enable-nvdec --enable-nvenc --enable-d3d11va --enable-dxva2 --enable-libmfx --enable-libshaderc --enable-vulkan --enable-libplacebo --enable-opencl --enable-libcdio --enable-libgme --enable-libmodplug --enable-libopenmpt --enable-libopencore-amrwb --enable-libmp3lame --enable-libshine --enable-libtheora --enable-libtwolame --enable-libvo-amrwbenc --enable-libilbc --enable-libgsm --enable-libopencore-amrnb --enable-libopus --enable-libspeex --enable-libvorbis --enable-ladspa --enable-libbs2b --enable-libflite --enable-libmysofa --enable-librubberband --enable-libsoxr --enable-chromaprint libavutil 57. 17.100 / 57. 17.100 libavcodec 59. 18.100 / 59. 18.100 libavformat 59. 16.100 / 59. 16.100 libavdevice 59. 4.100 / 59. 4.100 libavfilter 8. 24.100 / 8. 24.100 libswscale 6. 4.100 / 6. 4.100 libswresample 4. 3.100 / 4. 3.100 libpostproc 56. 3.100 / 56. 3.100 [mov,mp4,m4a,3gp,3g2,mj2 @ 000001f07753e340] Could not find codec parameters for stream 1 (Video: h264 (avc1 / 0x31637661), none, 1920x1080): unspecified pixel format Consider increasing the value for the 'analyzeduration' (0) and 'probesize' (5000000) options [mov,mp4,m4a,3gp,3g2,mj2 @ 000001f07753e340] Auto-inserting h264_mp4toannexb bitstream filter [mov,mp4,m4a,3gp,3g2,mj2 @ 000001f07753e340] could not find corresponding trex (id 2) [mov,mp4,m4a,3gp,3g2,mj2 @ 000001f07753e340] could not find corresponding track id 0 [mov,mp4,m4a,3gp,3g2,mj2 @ 000001f07753e340] trun track id unknown, no tfhd was found [mov,mp4,m4a,3gp,3g2,mj2 @ 000001f07753e340] error reading header [concat @ 000001f0775216c0] Impossible to open 'c:\test\739.m4s' [concat @ 000001f0775216c0] Could not find codec parameters for stream 1 (Video: h264 (avc1 / 0x31637661), none, 1920x1080): unspecified pixel format Consider increasing the value for the 'analyzeduration' (0) and 'probesize' (5000000) options Input #0, concat, from 'list.txt': Duration: N/A, bitrate: 189 kb/s Stream #0:0(und): Audio: aac (mp4a / 0x6134706D), 48000 Hz, stereo, fltp, 189 kb/s Metadata: handler_name : Brightcove m4f generator vendor_id : [0][0][0][0] Stream #0:1(und): Video: h264 (avc1 / 0x31637661), none, 1920x1080, SAR 1:1 DAR 16:9, 90k tbr, 90k tbn Metadata: handler_name : Brightcove m4f generator vendor_id : [0][0][0][0] Side data: unknown side data type 24 (169 bytes) Stream mapping: Stream #0:1 -> #0:0 (h264 (native) -> h264 (libx264)) Stream #0:0 -> #0:1 (aac (native) -> aac (native)) Press [q] to stop, [?] for help concate.txt: I/O error Cannot determine format of input stream 0:1 after EOF Error marking filters as finished Conversion failed!
Downloading a Widevine encrypted livesteam
By muppler in forum Video Streaming DownloadingReplies: 27Last Post: 28th Aug 2021, 17:10 -
Anyone have a new way to get decrypted key widevine And he wants to sell it
By magixter in forum Video Streaming DownloadingReplies: 0Last Post: 26th Jul 2021, 17:06 -
Widevine encrypted video
By Stevo1987 in forum Video Streaming DownloadingReplies: 1Last Post: 15th Jun 2021, 02:58 -
How Can I Download Encrypted Content Without Being Decrypted?
By Robert_ in forum Video Streaming DownloadingReplies: 1Last Post: 19th Aug 2020, 04:39 -
Modifying MPD File to Download Decrypted Version of Encrypted Video
By JFK in forum Video Streaming DownloadingReplies: 5Last Post: 13th Apr 2020, 08:36
