I am using the Shutter Encoder application on Windows to batch convert .MOV files, which provides the option of injecting custom FFMPEG commands for each file. The app natively offers overlay (drawtext) of timecode starting at 00:00:00:00. I also see that it knows and preserves the metadata time for each file as this is included in the commands "-metadata creation_time="2022-06-27T16:00:30.730888500Z"
I would like to have the timecode start at the creation time, and was wondering how I might be able to offset the timecode as such. Or...is there another way of overlaying (drawtext-ing) a time counter, starting at creation time? I would also like to overlay the creation date as well. Thanks in advance for your advice.
If ffmpeg cannot yet do this internally, you could always export the metadata (either using ffmpeg or exiftool or others), then use a subtitle editor to generate a subtitle of timecodes for overlay. then remux that sub back into the original media file. good thing there, is it is able to be switched off & on.
FFMPEG slows down over time
By bradwiggo in forum Newbie / General discussionsReplies: 4Last Post: 7th Jul 2021, 06:59 -
Concatenate video in ffmpeg -> time stamps problem
By nsenada in forum EditingReplies: 0Last Post: 30th Jan 2020, 14:38 -
how to add time counter of exist video file ?
By yanshof in forum ProgrammingReplies: 4Last Post: 10th May 2019, 02:57 -
ffmpeg cutting: how to get negative start time?
By Luke M in forum EditingReplies: 1Last Post: 25th Jul 2018, 11:00 -
Weird pixelization in recorded video from time to time
By martanius in forum Portable VideoReplies: 2Last Post: 28th May 2018, 16:03
