i am using audacity to edit audio and then i am exporting the audio as an aac by clicking on export audio in the main menu and then clicking on custom ffmpeg format options and then i am doing https://forum.videohelp.com/images/imgfiles/UI3Ib4d.jpg. as you can see i set 128 kb/sec bitrate
the problem is that when i check the properties of the aac file by using mediainfo it doesn't say the audio bitrate and it says variable for the bitrate. i need to add the aac file to mkvtoolnix and i mux an mkv file that has the new aac file that i made in audacity so that the audio bitrate shows. that's the first problem
the second problem is that i am not getting the bitrate that i am setting. for example assume that i set the bitrate to 128 kb/sec in audacity. when i check the audio bitrate in mediainfo after i mux the mkv file it is not saying 128 kb/sec and it is saying 127 kb/sec. i need to set it to 129 kb/sec in audacity so it says 128 kb/sec in mediainfo. that doesn't always work and i have to keep on trying different values in audacity. why is that happening? if i say 128 kb/sec in audacity then it should say 128 kb/sec in mediainfo and also i want the bitrate to show in the aac file and i don't want it to say variable
I don't think aac audio uses constant bitrate, only variable. The number given must be the average
The end of Audacity as we know it?
By super8rescue in forum AudioReplies: 22Last Post: 9th Jul 2021, 10:55 -
Audacity Settings
By biferi in forum Newbie / General discussionsReplies: 4Last Post: 20th Jan 2021, 15:45 -
Dithering Settings in Audacity
By Dabuss55 in forum AudioReplies: 4Last Post: 22nd Jun 2019, 06:52 -
How to remove hum using audacity?
By digicube in forum AudioReplies: 8Last Post: 1st Dec 2018, 18:04 -
Audacity help
By loa909 in forum Newbie / General discussionsReplies: 1Last Post: 26th Aug 2018, 13:34
