Results 31 to 36 of 36
That's absurd. I reviewed that last 6 or 7 of your own threads, 4 of which jagabo posted to, and all of his posts were helpful, informative, and well mannered, with no belittlement in sight (by him). You even thanked him a few times.
Better look in the mirror if you want to point out trigger-happy maledictors.
Scott -
Actually jagabo is perhaps the only guy on this forum who answers shortly (well, can be long and elaborate if it is fun) , only the questions and stays on the subject AND is correct. And you are pulling out an agenda on him. It is absurd, ignorance is a bliss.
Your truth is your truth - same like arse - everyone has own arse and everyone has own truth (i.e. yify video encoding settings). Seem You've already get answer for your question (different forum) - so please share it here so it can be provided to others with same problem.
You don't like this forum - me will be sad for the whole evening but at some point i will go to bed and tomorrow for sure forget about sadness.
HD BD bitrate is limited by H.264 HP@L4.0 (technically it can be H.264 HP@L4.1 capped to 40Mbps but it may fail with older BD players). -
1. Make the mp4 file with the -crf 19 setting (for example, because it can be crf 17 or 21 - it depends how much you care about the quality close to the original).
2. The resulting average bitrate is what you should be aiming for.
I set the average as it comes out, the maximum is 2x higher and it's OK.
Maybe it can be better, but it is enough.
Help - VHS to h.264, bit rate for archiving
By kamoo in forum Capturing and VCRReplies: 10Last Post: 20th Apr 2020, 14:10 -
Utvideo Constant Video Bit Rate
By chris319 in forum Video ConversionReplies: 3Last Post: 23rd Jan 2019, 15:29 -
increase bit rate! x264
By Kuronoe in forum Newbie / General discussionsReplies: 5Last Post: 9th Nov 2018, 15:39 -
Bit Rate Question
By chris319 in forum Capturing and VCRReplies: 9Last Post: 19th Oct 2018, 09:31 -
Broadcast Bit Rate
By chris319 in forum Newbie / General discussionsReplies: 45Last Post: 1st Sep 2018, 02:22
