how do i send files from an android phone to an ubuntu laptop using wifi?
like when ypu use wifi direct to send files between 2 andrpid phones?
Results 1 to 11 of 11
I use the Asus file manager on the phone which can access Windows shares,
perhaps installing Samba in Linux would provide similar functionality -
Not that many Linexers here, I think you'd get far better responses by searching ubuntuforums.org or askubuntu.com or posting a question there. Those are probably the best support sites for Linux.
Thread moved to the linux forum where you can get more help.
try with KDE-connect - https://www.fosslinux.com/45959/share-files-android-linux-wirelessly.htm
If you are trying to get files off an android phone using Ubuntu, install gmtp, plug your phone unto a usb port, choose the option to transfer files on your phone (as opposed to charge) and then you can browse the phone's filesystem.
I do it all the time, piece of cake. -
thanks all
i regularly transfer files between my phone and pc. my usb c connection works fine juat wondered if there was a wireless way of transferring files. cell phones have wi fi direct. was just amazed that there was no wi fi direct support on ununtu. -
"Programmers are human-shaped machines that transform alcohol into bugs."
I know it's not really what you're looking for, but you can also see if your phone will allow you to connect a USB flash drive directly for transferring files. I have a Galaxy S10+ that came with a USB > USB-C adapter; I can connect a flash drive using that, and use Total Commander (or whatever file manager you prefer) to copy or move files to and from the flash drive. Saves me the hassle of trying to connect to the phone, directly or remotely, or pull off the case so I can get at the MicroSD card.
Although, the forced update to Android 12 seems to have caused my phone to no longer properly recognize USB drives as removable drives? I'm not sure, but it no longer gives me the option to 'properly remove' USB drives. Either that, or I just haven't found it yet.
Downloading and decryption on your Android phone.
By A_n_g_e_l_a in forum Video Streaming DownloadingReplies: 28Last Post: 21st Oct 2023, 20:02 -
Fle recovery from android phone that wont boot.
By dafoe in forum Newbie / General discussionsReplies: 0Last Post: 18th Oct 2021, 21:22 -
Delete
By Ertoil in forum Authoring (DVD)Replies: 0Last Post: 3rd Aug 2021, 06:47 -
MKV/H264 to MP3 (or audio format compatible with Android phone)
By alexeliasson in forum AudioReplies: 2Last Post: 10th Feb 2021, 07:35 -
can i load ubuntu on this laptop ? and will blender vse work on it?
By oduodui in forum LinuxReplies: 8Last Post: 2nd Nov 2020, 04:37
