At least I think it's deinterlacing. I have my own DOS command line script already made up for items that do not need it, but just wondering what I should add to it to try and lessen this (see hands) when there's faster movement involved.
As much as I'd love to be able to use AviSynth, I've tried about a dozen times now and it's got my idiot-brain frazzled... hence my retreat to ffmpeg.
It's a 50yr-old British show, so 576p/25fps/Pal.
Realise I could set Handbrake to defaults and load it through that, but trying to increase my knowledge - little by little.
Let me know if I'm barking up the wrong tree and there's nothing I can do. It's watchable without doing anything to it, but once I've noticed this I can't help wishing to do something - if there is something - that'll lessen it.
Results 1 to 10 of 10
Deinterlace before resizing.
Code:-vf yadif=1,scale=640:480
https://files.videohelp.com/u/301446/shortsnip.mp4
https://files.videohelp.com/u/301446/snippet.mp4
Jagabo wins! Seems I may be too late for deinterlacing. You can see it on the top file, even though it's quite leisurely.
In the second file, it's particularly noticeable at the beginning.
Variable frame rate, x264, 854x480 is the nearest I can get to source too, and that's where the snippets are from.
Assuming this is past the point of deinterlacing?Last edited by SM1872; 25th Jun 2022 at 01:46.
One thing you can do is further blur the two fields together. That makes it look a little better when watching full screen. The attached video was made by downscaling to 854x240 the upscaling back to 854x480 (in AviSynth but any editor that lets you scale twice will work). Oh, I also decimated back to 25 fps to get rid of the duplicate frame every 6th frame.
Cheers Jagabo. Run it with any interlacing filters? Or just take those off?
The damage makes it impossible to deinterlace the video properly. That's why I suggested just blurring it. It's arguable whether that's really an improvement though. You're best bet is to find a true PAL version of the show.
Update: Finally got round to processing it.
Jagabo, that's amazing. It's almost completely gone. What an amazing trick. I doff my cap, and so on.
Than you so much for that. You're a genius.
Get the complete FFmpeg command line when using FFmpeg Batch Converter
By pascor in forum Newbie / General discussionsReplies: 8Last Post: 13th May 2021, 23:14 -
Please help with x264.exe command line for Full HD video
By Bencuri in forum Video ConversionReplies: 1Last Post: 24th Nov 2020, 18:52 -
Help - How encoding with Variable Frame Rate using x264 command line.
By Kuronoe in forum Newbie / General discussionsReplies: 7Last Post: 25th Feb 2020, 10:55 -
Need a command line for ffmpeg
By NTradd in forum Video ConversionReplies: 11Last Post: 14th Oct 2019, 11:25 -
ffmpeg command line help
By njscorpion in forum Newbie / General discussionsReplies: 2Last Post: 12th Jul 2019, 12:42
