I’m thinking of picking up a used 3D video camera. It saves 3D video files in the AVCHD format with MVC coding into an MTS container. How would I go about authoring a frame packed 3D Blu-ray iso that I could then burn? I currently have a MacBook Air. I’m guessing I might need to invest in a Windows laptop.
Get a Windows machine (preferrably a desktop) and a copy of a Windows Bluray authoring app that is known to support creation of BD3D, hopefully one that allows MVC source files without recompressing prior to importing into the authoring app. IIRC, VegasPro, combined with DVD Architect used to have that capability, but I don't know whether it still does since being sold to Magix. There were a few other tools. Cyberlink PowerProducer still says it can do that, but IIRC its output to BD3D is not the full-rez FramePacked format, but a SBS format, so you'll get 1/2 rez. Still better than nothing, but kind of a drag.
Most of the other options I know of are pro/semipro and cost $$$.
My suggestion is if you can, put your MVC files directly onto a medium that can be directly accessed by a 3DTV (e.g. usb stick). There is a possibility it should be able to directly read an MVC-encoded file and display it in 3D via its embedded media player.
Alternately, you could just play the MVC out via HDMI from a stereo3D-capable app on an HTPC (Windows), then no need to re-encode, assuming the app supports MVC (IIRC, many of the 3D apps were able to).
Best way to author sd blu ray
By NorvilleJones in forum Authoring (Blu-ray)Replies: 16Last Post: 3rd Sep 2021, 20:43 -
Converting VHS home movies to Blu Ray. How should I format the video files?
By Sixfortyfive in forum Authoring (Blu-ray)Replies: 14Last Post: 1st Jan 2021, 07:34 -
Blu ray player with frame advance and screen capture
By kmf828 in forum Software PlayingReplies: 3Last Post: 26th Dec 2019, 02:02 -
How to burn a blu-ray video disc using MKV files with these specs?
By robertazimmerman in forum Authoring (Blu-ray)Replies: 8Last Post: 25th Apr 2019, 22:14 -
Can a Blu-ray player play Blu-ray video burned on a DVD?
By digicube in forum Blu-ray RippingReplies: 2Last Post: 16th Jan 2019, 01:11
