Tried hlsdl, ytdlp, and streamlink, all are giving me trouble with the AES key length.
Looked around, tried turning it into hex, kind of lost on where to go now...
Here's the page with the video -If possible, please briefly explain how you got the key/the command you use, as there are many more videos to download.Code:https://remcm.cdn.spotlightr.com/publish/MjAxNjUy
Thanks!
Results 1 to 12 of 12
Need to use
key = 26c320ad3928c5f5e87e07d0fa3350e5d7bd3bdcf7e8d01141 400df30c51bd19hlsdl -K "key" -o "Spotlight.ts" "newm3u8.m3u8"
#EXTINF:3.200000,
5d6f66698e8b2833230135-1080-0.ts
#EXTINF:1.600000,
5d6f66698e8b2833230135-1080-1.ts
#EXTINF:1.600000,
5d6f66698e8b2833230135-1080-2.ts
#EXTINF:1.600000,
5d6f66698e8b2833230135-1080-3.ts
To :
#EXTINF:3.200000,
https://1693712952.rsc.cdn77.org/110038/5d6f66698e8b2833230135-1080-0.ts
#EXTINF:1.600000,
https://1693712952.rsc.cdn77.org/110038/5d6f66698e8b2833230135-1080-1.ts
#EXTINF:1.600000,
https://1693712952.rsc.cdn77.org/110038/5d6f66698e8b2833230135-1080-2.ts
#EXTINF:1.600000,
https://1693712952.rsc.cdn77.org/110038/5d6f66698e8b2833230135-1080-3.ts
software keeps changing e8d01141400df3 with e8d01141 400df3Last edited by jack_666; 21st Jun 2022 at 16:19. Reason: [QUOTE]software keeps changing e8d01141400df3 with e8d01141 400df3[/QUOTE]
this is odd, the m3u8 specifies using AES-128 which means a 16 byte key, but the .key returns a 32 byte key
#EXT-X-KEY:METHOD=AES-128,URI="5d6f66698e8b2833230135-1080-e.m3u8.key",IV=0x00000000000000000000000000000000
key = `26c320ad3928c5f5e87e07d0fa3350e5d7bd3bdcf7e8d0114 1400df30c51bd19` -
i have already download this (see my post#4 and see the date) but anyway here an interesting article about this site https://docs.spotlightr.com/en/articles/1479379-video-content-security
Uh, did you? Idk, I just did a simple search on github and it revealed this repo which happened to contain the respective code.
The original coder chose to make it public on github so I don't think you have any say over that. It was just waiting to be discovered.
https://github.com/search?q=spotlightr try it out. -
https://www.upload.ee/files/14255618/Spotlight.ts.html
Format : MPEG-4
Format profile : Base Media
Codec ID : isom (isom/iso2/avc1/mp41)
File size : 5.61 MiB
Duration : 2 min 22 s
Overall bit rate : 331 kb/s
Writing application : Lavf58.29.100Code:Stream Recorder - download HLS as MP4
Format : MPEG-4
Format profile : Base Media / Version 2
Codec ID : mp42 (isom/iso2/avc1/mp41/mp42)
File size : 6.15 MiB
Duration : 2 min 41 s
Overall bit rate : 320 kb/s
