Hi there,
I downloaded latest version of Potplayer from the official site. I first set its audio output to "Pass-through after AC3 re-encoding" and it works perfectly. Then I know the DTS is better than AC3 and try "Pass-through after DTS re-encoding" audio output, and it's no sound. I confirmed my HT receiver supports DTS input and it works.
Could anyone experienced with Poyplayer help me for this problem. Do I need install something, or change some settings in Potplayer to make it work?
Thanks in advance for your help.
P.S. I tried both 32bit and 64bit. The results are the same ("Pass-through after DTS re-encoding" won't work)
Similar problem here, I get sound but it's badly distorted.
What seems to be missing is just a "Pass-through" setting with no reencoding for streams that are directly compatible with our decoder, DD and DTS in my case.
Non linear audio delay in VirtualDub2 after "lossless encoding"
By Hunterh in forum Newbie / General discussionsReplies: 6Last Post: 16th Jan 2022, 07:21 -
PotPlayer 3 Qs: load exported settings; get rid of "Scenes(...)" tabs; etc
By fabiospark in forum Software PlayingReplies: 0Last Post: 1st Nov 2020, 11:36 -
XMedia Recode Problem "Colorful Stripes" in output
By hk_one0one in forum Video ConversionReplies: 2Last Post: 9th Jan 2019, 01:38 -
FFMpeg "non-monotonous DTS in output stream" error
By CursedLemon in forum Video ConversionReplies: 4Last Post: 26th Aug 2018, 09:56 -
Use "Line in" or "Microphone" jack as audio output.
By DonSeenu in forum AudioReplies: 3Last Post: 14th May 2018, 03:23
