    Aug 2015
    Quebec, Canada
    Hello all.
    I'm trying to reduce the fps of a video that is suppose to be at 23.976 fps but the streaming service has made it at 29.97 fps. Is there a way to reduce the fps without re-encoding ?
    I've tried mp4box but for an unknown reason it give me the good ftp but with a slower (In length).
    Is there another way ?
    Aug 2015
    Quebec, Canada
    I just made a few test with MKVtoolnix and set the default duration/fps to (24000/1001) and my file goes from 21.34 min (at 29.97 fps) to 26.58 min (at 23.976 fps), same thing as mp4box
    Mar 2008
    I don't think it's possible to do this with out reencoding the file
  4. You could try IVTC (inverse telecine) to restore the original 23.976 fps, but this will reencode your video.
  5. ffmpeg can fix this easily, but not without reencoding.
    ffmpeg -i input.mp4 -vf decimate -acodec copy -scodec copy -map 0 output.mp4
  6. Originally Posted by kalemvar1 View Post
    You can't decimate the video without re-encoding. Changing the frame rate the way you are is just telling the player to play the video slower, hence the longer running time.
