Hello
I'll try to explain this issue but it's hard in italian, in english will be even harder
Potplayer and Kmplayer (and othjer players i suppose) now displays movies with less contrast and higher brightness even if i didn't touch their settings
I tried to reinstall those software, and nothing changed
I tried to switch to Windows 11 and it seems all ok but then i found the same problem
It SEEMS (probably but there is something strange) that the issue is cause by AMD drivers
On a PC with very old drivers, i can't reproduce this issue. once i updated the drivers, the issue appeared.
i tried to switch to old drivers on my pc and it doesn't seem to work but later it worked!!!
I thought i found the solution, so i reinstalled windows because i had a bigger problem (security disappeared). i installed the same drivers.....but....no. i still got the issue.
maybe there is a combination of things that is causing it but i don't know where to look and search
Maybe in some log files?
if anyone has any ideas on what to do, please tell me
Results 1 to 1 of 1
USB-Live2 Brightness Issue (Video Example)
By JawsTDS in forum Capturing and VCRReplies: 8Last Post: 5th Jul 2019, 05:25 -
Rendered video brightness issue (Vegas)
By Welsh Jester in forum EditingReplies: 2Last Post: 6th Mar 2019, 06:10 -
Setting up the correct (or safe) Video Procs (Brightness, Contrast..)
By zerowalker in forum Capturing and VCRReplies: 7Last Post: 19th May 2018, 03:53 -
fixing brightness/contrast of black & white dvd
By x264 in forum RestorationReplies: 6Last Post: 4th Feb 2018, 13:18 -
Some problems with Movavi Video Editor 10 and contrast/brightness in videos
By WhamyKaBlamy in forum Newbie / General discussionsReplies: 3Last Post: 6th Aug 2017, 10:24
