Hi,
I used to download video from by getting the master.mpd url and using it in yt-dlp. Now, there isn't any master but an index.mpd and it doesn't work.
I've also tried to use HLS Downloader extension and nothing appear.
Where can I find some information about a tutorial on how to download videos like that ?
thanks in advance
example:
mpd: https://cdn4.vod.mcr.dorna.com/611303435d50a453f54ace20e9039082d6421d160d656077a93972e...1196/index.mpd
solution see post of cedric
Results 1 to 14 of 14
Try with ffmpeg
Code:ffmpeg -user_agent "Mozilla/5.0 (X11; Linux x86_64; rv:101.0) Gecko/20100101 Firefox/101.0" -headers "Cookie: auth.strategy=local; visid_incap_2379695=piMB6JQXT/aPlmuenWQUswDOrGIAAAAAQUIPAAAAAABgh/OWgTch/IpvTVDt3e+O; nlbi_2379695=392pVC/LaWmCo9yNiF4IcQAAAACVfoau9MbkEGT5K+aSMaKO; incap_ses_466_2379695=frRicM++Fmt/I5zjP5F3BgDOrGIAAAAAqsV94rgRyvs74B+epb3cjA==; _gcl_au=1.1.1060663411.1655492090; _ga=GA1.2.1476864080.1655491574; _gid=GA1.2.771399222.1655491574; _ga_0204YNR4C1=GS1.1.1655492095.1.1.1655492195.0; _tt_enable_cookie=1; _ttp=53543081-450a-49c3-af6a-1ee4ff4a8922; _ga_8P8SY3683N=GS1.1.1655492113.1.1.1655492219.0; auth._token.local=Bearer%20eyJ0eXAiOiJKV1QiLCJhbGciOiJSUzI1NiIsImtpZCI6IjRkYzRlNzQ1LWNmZmYtNDc2My04YjYwLTU2M2Y2OWNhM2MwNiJ9.eyJhdWQiOiJiMzJjYTE0Zi0wNzA5LTQ5NWEtOTE4NC04YmQ4NDhjZjdlNmIiLCJqdGkiOiJkMTU5ZjJjMmFiZTZkODZiYzFjZTRiZTBmNmEyZTA1OTRiM2VlMjVmYTBmYjViNzllZjM4OTFiM2ZlZDY2Y2JjNDJhMWY1MWM5MDY5N2U2OCIsImlhdCI6MTY1NTQ5MjIyNywibmJmIjoxNjU1NDkyMjI3LCJleHAiOjE2NjYwMzMwMjcsInN1YiI6IjYwMTRlZTZiLWE3OTctNDNmYS1hZGQxLWY2ZjU3ZWYyMTQ5YiIsInNjb3BlcyI6W10sInJvbGVzIjpbIlJPTEVfVVNFUiJdfQ.CmDQCvhz-nMFQ3ESNsUN33XLqrEZr0ahquGis6R81hNkm0rZawVCZIeWWFrTU3v4mX2DuNvBfEtJS8mOmfNpjulafmjZR1lum08ZIzAq2UM3vFOaPXshpi19SNKeC2TPrZQUVZwSELnkiVx3PYdPsesD-1iV0d6zAqywuQYVAwHpaBi44_GwVtogMMEZONHZP5SnaPnsYGJocccIdwieT78lY4Rs1aCLoXbeSFX-d0YTe-M5nGfACn8HDMExgl7chXMeb0BH8grbl3f0rrN1CeN6C6BnSnMfsV0gXt6PwBUZVO9ssk3CPwQj1V9AHKhlqIxFbYk_dfRa_2M0aS4r4Q; auth._token_expiration.local=1666033027000; auth._refresh_token.local=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; auth._refresh_token_expiration.local=1658084218692" -referer "https://www.motogp.com/" -i "https://cdn4.vod.mcr.dorna.com/e9d5d915e9654428cef726f058a2754822b4d33e695738d5ba4a12dd49e8fa3a/1655494815/xtkro4THmV3Lykasdj1SN0GdhHNJW%2FP%2Bj%2F4x23dbdc50%2BKuT18VYkzt3s7fX3yo2/101152/index.mpd" -c copy "index.ts"
thanks for the help cedric.
can you explain how you got the auth._token.local, auth._token_expiration.local, auth._refresh_token.local, auth._refresh_token_expiration.local, gid, ga, ttp ?
I looked with the console but I might not looked at the right place.
with your command line, how would you specify a resolution (available from the stream) like 720p.
cheers -
tanks cedric for your hint, anyway with yt-dlp download from mpd not work. wired
i think mpd is wrong. for this i have try to download from dash stream, add cookie and output like -o vid.ts
but no luck ... download don't start
also i have try to download mpd and edit but nothing work
someone have an alternative solution to download with yt-dlp? -
why you have delete your link? this link is public, and maybe need some user to bypass you same issue
and also whs912km raises a question still to be solved ...
and they never delete links, they serve everyone
the link was this: (let's see if you can delete my post too... )
and also i want post here a fake link, which i created, and that you could have done for all those who helped you or read your postCode:https://www.motogp.com/en/videos/2022/06/17/are-riders-feeling-the-heat-in-germany/425638
Code:bacan81661@giftcv.com bacan81661@HNBRT
I wanted to avoid the admin of the link to find this post in case they are looking to increase their security ... can't see why this is wrong, the explanation work for a link containing the "index.mpd". if someone else had the same issue there is enough information to get it working.
I don't care if it's working with ffmpeg, i didn't ask to make it work with ytb-dl, as a result in my point of view the topic is solved
have a nice day and chill out -
@lomero, thanks for preserving the link.
... Very funnyI wanted to avoid the admin of the link to find this post in case they are looking to increase their security
Sad situation when people get what they want and delete info that would help others
Again, thanks lomero -
https://chrome.google.com/webstore/detail/live-cat/cofmpiaddiioohphmmgjnbcpfoiknnkh
Help Downloading MPD File
By thegeek in forum Video Streaming DownloadingReplies: 4Last Post: 12th Apr 2021, 05:46 -
Help downloading MPD from Kanopy
By dzigelbaum in forum Video Streaming DownloadingReplies: 11Last Post: 9th Apr 2021, 22:07 -
Help downloading MPD Dash
By axnspain in forum Video Streaming DownloadingReplies: 2Last Post: 9th Dec 2020, 03:09 -
Help downloading manifest mpd
By therain in forum Video Streaming DownloadingReplies: 1Last Post: 3rd Nov 2020, 13:26 -
Need help downloading mpd fragments
By sp123 in forum Video Streaming DownloadingReplies: 4Last Post: 17th Jan 2019, 11:25
