First try to encode to x265 with the latest ffmpeg and it comes out that the "slower" preset generates a larger file than the default...
[Attachment 65456 - Click to enlarge]
A slower preset spends more time searching for similarities in the video. That doesn't guarantee it can actually find a way to encode the video content with less data. Some slower presets enable the use of algorithms which may save some space in the average case but may as well need more space than more simple algorithms in the worst case for them.
The larger size on the slower presets has been mentioned a few times
in this forum, this seems to be the way it works in X265 -
Like x264, x265 enables settings that give better image quality (and require more bitrate) as you go to slower settings. So moving to slower presets doesn't necessarily mean you will get more compression.
Does setting the ffmpeg -preset affect quality? Does Handbrake preset?
By LaserBones in forum Newbie / General discussionsReplies: 7Last Post: 15th Jul 2020, 13:01 -
The Holy Grail settings of NVENC HEVC.Can you find better preset? (CONTEST)
By Abdler in forum Video ConversionReplies: 16Last Post: 6th May 2020, 15:00 -
ffmpeg preset
By vidblue in forum Video ConversionReplies: 1Last Post: 4th Apr 2020, 16:03 -
MAGIX HEVC/AAC MP4 settings, preset quality, what does it affect?
By SF01 in forum EditingReplies: 5Last Post: 14th Mar 2020, 13:07 -
What hevc nvenc settings do work with lossless preset in ffmpeg?
By qo4on in forum Video ConversionReplies: 3Last Post: 9th Mar 2020, 04:14
