Hi all,
so I've been using VSDC for a while now and made some simple but nice videos.
One thing though seems overly complicated for me and I wonder if I'm simply doing it wrong or if VSDC come to its limits with creating shapes:
For example I made several arrows out of the free shape tool by placing all the shape points seperately. That seemed pretty complicated already but i thouhgt hey, once some shape are made i can just adjust and group them together like making a double arrow out of one single arrow. When I group souch a compound shape (like the double arrow) or make a sprite out of it I cant even rotate that anymore.
How do you create descriptive shapes in videos just like in a way you are used to do that in Power Point? I'm about to create several videos but if that thing is going to be pretty time consuming I might have to think about other tools (also for that I'd appreciated your experiences).
Thanks for any advice!
If the arrows are not to be moving in your video then use a photo editing program to create an arrow and save it as a JPG file and overlay it in your video editing program. That's the easy way I do it. If the arrow has to move around in your video then most video editing programs can do that also.
Extraordinary claims require extraordinary evidence -Carl Sagan -
Thanks TreeTops. In fact I did that one time when I used an arrow with a sort of brush style. If there has to be a tiny change to it you cannot really tweak it a lot and it ends up in a similar situation. Nevertheless your idea is still good, because it is way easier and faster to design shapes in any editing software!!
Red/Green arrows
By weybrew in forum Newbie / General discussionsReplies: 4Last Post: 30th Apr 2022, 23:29 -
Weird compression shapes all over the video
By killerteengohan in forum RestorationReplies: 6Last Post: 9th May 2021, 22:03 -
Vsdc
By shelley8 in forum EditingReplies: 3Last Post: 16th Sep 2020, 10:21 -
Vsdc
By vunopawe in forum Newbie / General discussionsReplies: 0Last Post: 10th Dec 2019, 01:54 -
VSDC adding arrows
By Jon1 in forum EditingReplies: 0Last Post: 8th Oct 2019, 05:47
