  1. Hi all, I'm very happy to be here!!!
    I'm looking for this fantastic software Staxrip, because I found this is very very powerful and work with my Radeon RX6600 encoder ( VCEEnc ).
    I'm really going crazy with one file with the following info:
    _________________________________________________
    Unique ID : 323049640638934314631970778662089065617 (0xF30918FF21CD262733988A0EFB150491)
    Complete name : E:\4K\Gemini Man.mkv
    Format : Matroska
    Format version : Version 2
    File size : 22.9 GiB
    Duration : 1 h 57 min
    Overall bit rate : 28.0 Mb/s
    Encoded date : UTC 2020-05-06 11:49:35
    Writing application : mkvmerge v45.0.0 ('Heaven in Pennies') 64-bit
    Writing library : libebml v1.3.10 + libmatroska v1.5.2
    Video
    Format : HEVC
    Format/Info : High Efficiency Video Coding
    Format profile : Main 10@L5.1@High
    HDR format : SMPTE ST 2086, HDR10 compatible
    Codec ID : V_MPEGH/ISO/HEVC
    Bit rate : 26.0 Mb/s
    Width : 3 840 pixels
    Height : 2 076 pixels
    Display aspect ratio : 1.85:1
    Frame rate mode : Constant
    Frame rate : 59.940 (60000/1001) FPS
    Color space : YUV
    Chroma subsampling : 4:2:0 (Type 2)
    Bit depth : 10 bits
    Bits/(Pixel*Frame) : 0.054
    Stream size : 21.3 GiB (93%)
    Writing library : x265 3.3+1-g396395b2b:[Windows][GCC 9.2.0][64 bit] 10bit
    Encoding settings : cpuid=1049583 / frame-threads=3 / numa-pools=12 / wpp / no-pmode / no-pme / no-psnr / no-ssim / log-level=2 / input-csp=1 / input-res=3840x2076 / interlace=0 / total-frames=420962 / level-idc=51 / high-tier=1 / uhd-bd=0 / ref=4 / no-allow-non-conformance / repeat-headers / annexb / no-aud / hrd / info / hash=0 / no-temporal-layers / open-gop / min-keyint=25 / keyint=250 / gop-lookahead=0 / bframes=8 / b-adapt=2 / b-pyramid / bframe-bias=0 / rc-lookahead=40 / lookahead-slices=4 / scenecut=40 / hist-scenecut=0 / radl=0 / no-splice / no-intra-refresh / ctu=64 / min-cu-size=8 / rect / no-amp / max-tu-size=32 / tu-inter-depth=1 / tu-intra-depth=1 / limit-tu=0 / rdoq-level=2 / dynamic-rd=0.00 / no-ssim-rd / signhide / no-tskip / nr-intra=0 / nr-inter=0 / no-constrained-intra / no-strong-intra-smoothing / max-merge=3 / limit-refs=3 / limit-modes / me=3 / subme=5 / merange=57 / temporal-mvp / no-frame-dup / no-hme / weightp / weightb / no-analyze-src-pics / deblock=-3:-3 / no-sao / no-sao-non-deblock / rd=4 / selective-sao=0 / no-early-skip / rskip / no-fast-intra / no-tskip-fast / no-cu-lossless / no-b-intra / no-splitrd-skip / rdpenalty=0 / psy-rd=2.00 / psy-rdoq=1.00 / no-rd-refine / no-lossless / cbqpoffs=0 / crqpoffs=0 / rc=crf / crf=17.0 / qcomp=0.65 / qpstep=4 / stats-write=0 / stats-read=0 / vbv-maxrate=160000 / vbv-bufsize=160000 / vbv-init=0.9 / crf-max=0.0 / crf-min=0.0 / ipratio=1.30 / pbratio=1.20 / aq-mode=3 / aq-strength=0.80 / cutree / zone-count=0 / no-strict-cbr / qg-size=32 / no-rc-grain / qpmax=69 / qpmin=0 / no-const-vbv / sar=1 / overscan=0 / videoformat=5 / range=0 / colorprim=9 / transfer=16 / colormatrix=9 / chromaloc=1 / chromaloc-top=2 / chromaloc-bottom=2 / display-window=0 / master-display=G(13250,34500)B(7500,3000)R(34000,16000)WP (15635,16450)L(10000000,10) / cll=5180,1577 / min-luma=0 / max-luma=1023 / log2-max-poc-lsb=8 / vui-timing-info / vui-hrd-info / slices=1 / no-opt-qp-pps / no-opt-ref-list-length-pps / no-multi-pass-opt-rps / scenecut-bias=0.05 / hist-threshold=0.01 / no-opt-cu-delta-qp / no-aq-motion / hdr10 / hdr10-opt / no-dhdr10-opt / no-idr-recovery-sei / analysis-reuse-level=0 / analysis-save-reuse-level=0 / analysis-load-reuse-level=0 / scale-factor=0 / refine-intra=0 / refine-inter=0 / refine-mv=1 / refine-ctu-distortion=0 / no-limit-sao / ctu-info=0 / no-lowpass-dct / refine-analysis-type=0 / copy-pic=1 / max-ausize-factor=1.0 / no-dynamic-refine / no-single-sei / no-hevc-aq / no-svt / no-field / qp-adaptation-range=1.00 / no-scenecut-aware-qpconformance-window-offsets / right=0 / bottom=0
    Language : English
    Default : Yes
    Forced : No
    Color range : Limited
    Color primaries : BT.2020
    Transfer characteristics : PQ
    Matrix coefficients : BT.2020 non-constant
    Mastering display color primaries : Display P3
    Mastering display luminance : min: 0.0010 cd/m2, max: 1000 cd/m2
    Maximum Content Light Level : 5180 cd/m2
    Maximum Frame-Average Light Level : 1577 cd/m2
    I'd like to convert It to a 30fps file, but using Staxrip I'm not able to do this, I tried almost everything in AVS Filter - Frame Rate but really impossible to reach the goal.
    Does anyone can help me to understand how to manage this ?
    Thank you
  2. SelectEven() or SelectOdd() or ChangeFPS(30000/1001)... All of those will remove every other frame and leave you with 29.97 fps (30000/1001).
  3. Originally Posted by jagabo View Post
    SelectEven() or SelectOdd() or ChangeFPS(30)...
    I tried these but there are several problems...
    If I use SelectEven(), nothing change in the output file, I read 59,94fps
    [Attachment 65396 - Click to enlarge]
    If I use SelectOdd(), I receive an error and I have to move the slice to resize to 3840x2080, but the output file will be 3840,1040 with same FPS
    [Attachment 65399 - Click to enlarge]
    I also noticed that If I move, in AVS filter, the "resize" line above "field", the output file will be 3840x2080 but still 59,94fps. It's the same for Select Even
    [Attachment 65400 - Click to enlarge]
    If I use ChangeFPS(30), It seems correct, but I have to choose Avisynth/VapourSynth for the decoder
    [Attachment 65402 - Click to enlarge]
    [Attachment 65403 - Click to enlarge]
    If I choose VCEEnc for decoding the original file, the output file will still be @ 59,94fps, but It's not visible in the main screen but after I start the job
    [Attachment 65404 - Click to enlarge]
    [Attachment 65405 - Click to enlarge]
    For sure there's something I don't know because I'm a new user, could you please explain better my lack of knowledge and the best way to manage these?
    Thank you
    Mar 2008
    The two select filters you tried are not as jagabo advised (frame decimation) those appear to be field operations.
    Use Avisynth as the source decoder/frameserver and either use Changefps, or you can try SelectEvery(2,0)
  5. Originally Posted by davexnet View Post
    Ok i will try, anyway cannot fine any other selecteven or selectodd. In any case, why cannot use the gpu as decoder? I would try to find the solution that avoid the usage of the gpu...
  6. Yes, SelectEvery(2,0) or SelectEvery(2,1) will work.
