Hi
I am new to using ffmpeg.
I want to create a bat fie that I can drag and drop a video file to and it will create a scaled down version with burnt-in-timecode
I've found out how to scale down and burn-in the timecode in the following script but only from timecode 00:00:00:00
I can't figure out how to get the first frame timecode and put that in as a variable.Code:@echo off pushd for %%i in (%*) do if not exist "%%~ni_proxy%%~xi" ( ffmpeg -i "%%~i" -acodec copy -vf "drawtext=fontfile=C\\:/Windows/fonts/arial.ttf:fontsize=72:fontcolor='white':timecode='00\:00\:00\:00':rate=25:text='TCR\:':boxcolor=0x000000AA:box=1:x=(w-text_w)/2:y=20, scale=640:-1" "%%~ni_proxy%%~xi" ) popd echo Completed pause
I have seen some suggestions to use ffprobe?
In my example file the timecode should be 10:00:00:00
Here is a mediainfo dump of an example file:
Code:General Complete name : C:\temp\test.mov Format : MPEG-4 Format profile : QuickTime Codec ID : qt 0000.02 (qt ) File size : 227 MiB Duration : 30 s 0 ms Overall bit rate : 63.5 Mb/s Writing application : Lavf58.29.100 Video ID : 1 Format : HEVC Format/Info : High Efficiency Video Coding Format profile : Main 10@L5@High Codec ID : hev1 Codec ID/Info : High Efficiency Video Coding Duration : 30 s 0 ms Bit rate : 56.6 Mb/s Width : 3 840 pixels Height : 2 160 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 25.000 FPS Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 10 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.273 Stream size : 202 MiB (89%) Language : English SEI_rbsp_stop_one_bit : Missing Codec configuration box : hvcC Audio #1 ID : 2 Format : PCM Format settings : Little / Signed Codec ID : in24 Duration : 30 s 0 ms Bit rate mode : Constant Bit rate : 1 152 kb/s Channel(s) : 1 channel Channel layout : L Sampling rate : 48.0 kHz Bit depth : 24 bits Stream size : 4.12 MiB (2%) Default : Yes Alternate group : 1 Audio #2 ID : 3 Format : PCM Format settings : Little / Signed Codec ID : in24 Duration : 30 s 0 ms Bit rate mode : Constant Bit rate : 1 152 kb/s Channel(s) : 1 channel Channel layout : R Sampling rate : 48.0 kHz Bit depth : 24 bits Stream size : 4.12 MiB (2%) Default : Yes Alternate group : 2 Audio #3 ID : 4 Format : PCM Format settings : Little / Signed Codec ID : in24 Duration : 30 s 0 ms Bit rate mode : Constant Bit rate : 1 152 kb/s Channel(s) : 1 channel Sampling rate : 48.0 kHz Bit depth : 24 bits Stream size : 4.12 MiB (2%) Default : No Alternate group : 3 Audio #4 ID : 5 Format : PCM Format settings : Little / Signed Codec ID : in24 Duration : 30 s 0 ms Bit rate mode : Constant Bit rate : 1 152 kb/s Channel(s) : 1 channel Sampling rate : 48.0 kHz Bit depth : 24 bits Stream size : 4.12 MiB (2%) Default : No Alternate group : 4 Audio #5 ID : 6 Format : PCM Format settings : Little / Signed Codec ID : in24 Duration : 30 s 0 ms Bit rate mode : Constant Bit rate : 1 152 kb/s Channel(s) : 1 channel Sampling rate : 48.0 kHz Bit depth : 24 bits Stream size : 4.12 MiB (2%) Default : No Alternate group : 5 Audio #6 ID : 7 Format : PCM Format settings : Little / Signed Codec ID : in24 Duration : 30 s 0 ms Bit rate mode : Constant Bit rate : 1 152 kb/s Channel(s) : 1 channel Sampling rate : 48.0 kHz Bit depth : 24 bits Stream size : 4.12 MiB (2%) Default : No Alternate group : 6 Other ID : 8 Type : Time code Format : QuickTime TC Duration : 30 s 0 ms Frame rate : 25.000 FPS Time code of first frame : 10:00:00:00 Time code of last frame : 10:00:29:24 Time code, striped : Yes Language : English Default : No
Results 1 to 1 of 1
Timecode <==> frame number tool?
By Ennio in forum Newbie / General discussionsReplies: 32Last Post: 11th May 2023, 20:13 -
Future dates in timecode
By markpritchett in forum Capturing and VCRReplies: 2Last Post: 12th Jun 2021, 02:38 -
How to remove a timecode?
By johnrock in forum EditingReplies: 2Last Post: 6th Feb 2021, 14:07 -
Timecode VS Time
By SubtitleNoob in forum SubtitleReplies: 2Last Post: 1st Aug 2020, 14:06 -
How do I get the timecode of the first frame using a command-line tool?
By Simon_Haddad in forum Video ConversionReplies: 0Last Post: 12th Jun 2020, 19:32
