Hi everyone. I have two recordings from two VHS tapes of one video material. Codec video is huffyuv. There are damage to the image in each of them, but in different places. After analyzing the material, I could compile one movie. Does anyone have an avisynth script in which you can simply transfer single frames from one video to another video material, or the entire specified range, e.g. frame 210 from number 1, overwrite frame 320 in movie 2 of the video material, leaving the original sound in the target movie 2, in which image should be fixed ??. I want to avoid cuts with the "Trim" method ( it also translates from one bad audio file to another.. ), just simply translate the image frames. My head is bursting with combining and I can't think of anything
. If anyone has an idea for a script, please send me an example .. I'll try to adapt it to my own needs. Regards.
Try the Median() filter. It was made just for this type of problem.
http://avisynth.nl/index.php/Median
For manual replacements you can use ReplaceFramesSimple(), included in the RemapFrames package.
http://avisynth.nl/index.php/RemapFrames
Extract frames as uncompressed image files
By Fern99 in forum Newbie / General discussionsReplies: 4Last Post: 22nd Jul 2021, 11:42 -
Editing with face swap
By crabbyc in forum EditingReplies: 1Last Post: 8th Dec 2019, 16:22 -
output location of frames similar to image to Text
By Budman1 in forum EditingReplies: 2Last Post: 29th Jun 2019, 23:53 -
HDD swap on CCTV DVR
By visionman in forum Newbie / General discussionsReplies: 1Last Post: 15th Jun 2018, 13:29 -
Is it possible to swap RL to LR in SBS with XMedia Recode?
By slit in forum Newbie / General discussionsReplies: 2Last Post: 9th Jul 2017, 18:12
