  1. How many Minutes Long can a Video be that I can Upload to FaceBook?
    I Looked on Google and it Says it should be 1080 Resolution and Under 60 Minutes Long.
    Then I See some other Topic Says the Video should be Under 120 Minutes Long.
    I do not have a Business FaceBook Account.
    May 2005
    PAL User
    I'm uploading 1440P videos to Facebook, and 1440P is available on the video's settings (cog) icon. I don't know about the maximum length.
  3. DECEASED
    Jun 2009
    Heaven
    AFAIR there is no maximum duration for the videos on Facebook.
    "Programmers are human-shaped machines that transform alcohol into bugs."
  4. Generally, the recommended maximum length for personal accounts is 60 minutes, and the resolution should be 1080p. However, there are instances where the limit might be extended to 120 minutes. Since you mentioned having a personal account, I'd stick with the 60-minute guideline to be safe
  5. I guess you can upload videos up to a maximum length of 240 minutes (4 hours).
    May 2005
    PAL User
  7. Generally, the recommended maximum length for personal accounts is 60 minutes, and the resolution should be 1080p. However, there are instances where the limit might be extended to 120 minutes. Since you mentioned having a personal account, I'd stick with the 60-minute guideline to be safe. You can explore the extended options if you ever upgrade to a business account. If you need a business account quickly, check out Social Media Accounts for Sale - Facebook, Instagram and more. I hope that helps.
  8. You can now download 120 Minutes. Facebook is embracing it even)
