You're a VH troll. Go away.
Plenty? No.
Some decent options? Perhaps. As with anything else in this Win10/11 era, there are caveats. I know that some users have found some, but it does tend to be PAL/NTSC specific as well. The era of easy capture is over, unless you're willing to use legacy OS and cards, and there's really no reason to resist legacy. You shouldn't be using your daily online system for video capture.
Closed Thread
Results 31 to 33 of 33
Are you calling me a troll because I expect you to explain your dismissive comment? Since this is a technical forum as dellsam34 suggests, a technical answer will suffice. After all, what could be more technical and less ambiguous than math? Please, share some pearls of your wisdom. So far, it is you who is making perfunctory comments regarding others' equipment and techniques.
I don't see how attacking forum members is technical. You are not the first phenomenon, We've seen members behaving the same way before that are banned now, Babydav, Truthler and the likes.
Output PAL 576i over HDMI from PC then Input to BMD Decklink?
By 213 in forum Newbie / General discussionsReplies: 10Last Post: 24th Jan 2022, 14:26 -
Magewell USB Capture HDMI - Can't read device with 2 apps at the same time
By calande in forum Capturing and VCRReplies: 2Last Post: 17th Dec 2021, 02:53 -
Cable box > HDMI audio receiver > HDMI splitter > Capture card?
By ArianK in forum AudioReplies: 0Last Post: 6th May 2021, 04:18 -
HDMI capture softwares and lossless video compressors support the XV.Color
By Harvie Winters in forum Newbie / General discussionsReplies: 1Last Post: 1st Jul 2020, 16:56 -
HDMI video - compression and uncompressed and bitrates
By Christopher2222 in forum Capturing and VCRReplies: 1Last Post: 14th Feb 2018, 10:28
