This is something that has been bothering me since forever. Is there some way to have Windows display consistent decimal places for folder/file sizes when looking at the properties?
Windows seems to use just 3 digits, so with if you have a 3 integer digits you get no decimals. This is unacceptable since you can be off by whole GBs. If you have +10TB sizes you get 0.1 precision (100GB). Absolute crap. Only way to get an accurate reading is to type the bytes in the calculator and divide them by 1024 till you get to your unit. And typing bytes for TB sizes is a pain in the ass.
See the attachment for examples, with the actual sizes up to 3 decimals beside (last one is .050 so .05)
The regional settings has one for digits after decimal but it has no effect on file sizes. Any registry edit or something to get consistent decimal digits? I'd be happy with two, like 123.45 GB.
Toast giving inaccurate file sizes
By Kal-El in forum MacReplies: 0Last Post: 10th Oct 2020, 14:08 -
Manageable File Sizes for Editing
By teddybouch in forum Video ConversionReplies: 5Last Post: 27th May 2020, 10:01 -
x265 CRF Encoding - Quality & file sizes.
By pezwf in forum Newbie / General discussionsReplies: 17Last Post: 12th May 2020, 02:25 -
Converted MP4 Files Do Not Display Length, Data Rate, Frame Under Windows
By pone44 in forum Video ConversionReplies: 4Last Post: 24th Jun 2019, 02:14 -
Huge DVD VOB file sizes
By torquay7 in forum Newbie / General discussionsReplies: 10Last Post: 26th Nov 2018, 14:35
