  1. I'm currently using Nerov5.5.8.0 I have found out that if i burn a vcd 352x288(PAL), and an SVCD 480x576(PAL) it wont play on my SHARP DV-740 which everyone says its compatible for any vcd and svcd. Can anyone help me how can i fix this are there any suggestions. My DVD player will play 352x240 (NTSC), and 480x480(NTSC) play just fine im only having trouble with the PAL ones someone pls help :(
    Feb 2002
    Oregon
    If your TV receiver is NTSC then you must modify the remote (see the Area 450 mod) in order to get the 740U to output NTSC when playing a PAL disk.
  3. Sorry for the stupid question but what exactly do u mean by "modify the remote (see the Area 450 mod)"
    Feb 2002
    Oregon
    For an explanation go to: http://www.area450.com/thesampozone/players/dv740external.htm
    Basically the Sharp 740U plays both NTSC and PAL and will convert from one system to the other but the remote button to allow conversion is hidden under the front cover. All you have to do is drill a small hole in the right spot to access the button.
    If you want to make the 740U region free there is also a simple hack at the above address.
    Good luck!
  5. THX I got it working thx
