Does anyone use WinDVR to capture with? I thought I had it all setup capturing good and then I changed channels and my results totally changed. Is this normal? I am capturing with my cable signal.
One thing you need to know about cable signal
Cable signal varies from channel to channel, each one is on a different frequency, that would cause your problem,
Try passing the Cable signal through a VCR ( some boost the signal )
If that does not work maybe try running the cable into the card using RCA jacks or S-Video ( digital cable only with digital box )
That set up gives me excellent picture quality
HTH
Spooky"Computers are stupid, but they are capable of being stupid one million times per second"
Intervideo WinDVR 3 wont record more than 10 minutes
By goshtin in forum Capturing and VCRReplies: 1Last Post: 8th Feb 2012, 15:11 -
About windvr and easygrabber 2.0 capture.
By MidnightMike in forum Video Streaming DownloadingReplies: 3Last Post: 15th Dec 2010, 18:32 -
windvr 3 and no sound
By goodtilltomorrow in forum Capturing and VCRReplies: 6Last Post: 12th Oct 2008, 17:34 -
InterVideo WinDVR 3: "The specified capture format is not supported on
By SignedupGuest in forum Newbie / General discussionsReplies: 1Last Post: 17th Sep 2008, 20:01 -
WinDVR Input disappears while recording
By jacx3 in forum Capturing and VCRReplies: 2Last Post: 24th Feb 2008, 12:39
