I'm trying to reencode a short video clip. It will be joined with others that all have 4 reference frames. My source file has 4 reference frames. No matter what I do, ffmpeg always spits out a file with 3 reference frames. Is there a bug in the software or some reason I'm unaware that this is not working?
This is the command I used:
ffmpeg -i input.mkv -c:v libx264 -preset medium -tune film -crf 13 -max_muxing_queue_size 1000 -x264-params keyint=24:bluray-compat=1lices=4:level=4.1:ref=4:fps=24000/1001 -bsf:v dump_extra=freq=k output.mkv
This is the source mediainfo:
Video
ID in the original source medium : 4113 (0x1011)
Format : AVC
Format profile : High@L4.1
Format settings : CABAC / 4 Ref Frames
Format settings, CABAC : Yes
Format settings, Reference frames : 4 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 3 min 51 s
Bit rate mode : Variable
Bit rate : 25.1 Mb/s
Maximum bit rate : 33.0 Mb/s
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.506
Stream size : 694 MiB (100%)
Language : English
Default : No
Forced : No
This is the resulting mediainfo:
Video
Format : AVC
Format settings : CABAC / 3 Ref Frames
Format settings, Reference frames : 3 frames
Color space : YUV
Bit depth : 8 bits
Stream size : 694 MiB (93%)
Writing library : x264 core 164 r3075 66a5bc1
Encoding settings : cabac=1 / ref=4 / deblock=1:-1:-1 / analyse=0x3:0x113 / me=hex / subme=7 / psy=1 / psy_rd=1.00:0.15 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-3 / threads=24 / lookahead_threads=4 / sliced_threads=0 / slices=4 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=1 / constrained_intra=0 / bframes=3 / b_pyramid=1 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=1 / keyint=24 / keyint_min=1 / scenecut=40 / intra_refresh=0 / rc_lookahead=24 / rc=crf / mbtree=1 / crf=13.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
Language : English
Default : No
Forced : No
You can see in the "Encoding settings" section in the resulting mediainfo that it picked up the command to use 4 reference frames. But for some reason it insists on 3. Any ideas?
Worked for me without the bluray compat flag. Must be something there. Thanks for the tip!
Ref Frames,Timescale, sharpen and Short Audio questions
By Budman1 in forum Video ConversionReplies: 3Last Post: 2nd Oct 2021, 15:44 -
Number of reference frames x264
By Surlias in forum Newbie / General discussionsReplies: 17Last Post: 17th Mar 2019, 13:32 -
x264 with manually setted "ref" parameter and MediaInfo report not the same
By aleaksunder in forum Video ConversionReplies: 2Last Post: 21st Feb 2019, 03:53 -
FFMPEG x264 parameters
By marcorocchini in forum Newbie / General discussionsReplies: 6Last Post: 4th Aug 2018, 11:21 -
Can I force ffmpeg to transcode 59.94 frames to display at 25 frames per se
By oduodui in forum EditingReplies: 4Last Post: 28th Apr 2018, 09:24
