I've had pretty good luck with TMPGEnc with converting alot of different formats to VCD MPG, but some ASF's and MPG's totally freeze it up. I've used ASF Tools to fix the ASF's but they still didn't work, then I fixed them and then tried to convert them to AVI's and then TMPGEnc says they are invalid. I've tried to use an MPEG fixer to fix the MPG's but that still doesn't work. I tried to use Virtual Dub on the mpg's that don't work and VB says the mpgs are ASF which it doesn't support.
Well if anyone has any ideas I'd be grateful,
Ryan
