Hi, all!
I'm looking to create a blank/mute AVI file that's just a black screen with no audio, and that's less than 1 second long, ideally 0.1 or 0.2 seconds.
I'm doing this to create a simple mod, where all the unskippable intro movies in the game MVP Baseball 2005 are replaced by this short mute blank file that's only 0.1/2 seconds long.
Seeing how the game plays three unskippable movies consecutively that are around ~5 seconds long, this mod would be such a relief to have.
Anyway, the AVI file's metadata has to be:
- Resolution: 640x480
- Aspect Ratio: 4:3
- FPS: 25
The only thing missing is the duration, which is, as I said preferably 0.1 or 0.2 seconds long.
The in-game files are in VP6 extension, that is, they use the On2's VP60 video codec, and I did manage to find a way how to compress AVI files using that codec, so the only thing remaining is to create an actual AVI file that I will convert to VP6.
Now, I did manage to find a blank AVI file from someone on videohelp.com (here), but the problem is that file is 5 seconds long, and I couldn't manage to find a way on how to trim AVI files, without them being corrupted or changing extensions.
So I can do this in two ways:
Either I find a way to trim this 5-seconds AVI video file that I downloaded, or I create a new AVI file with my specified length, and properties, and compress it using On2's VP6 codec using VirtualDub
I think I would prefer the latter option, as I believe it is less complex than the former one.
So, does anyone know how can I achieve this? What software would I need to use, and how could I create such a file?
Thanks in forward!
Closed Thread
Install AVISynth. Create a text file with extension *.avs. You need only one line:
BlankClip(parameters)
Google for parameters for your special needs, very simple.
Open with VirtualDub, save video.
tetsuro1-please do not open another thread on the same subject,one thread is enough,this thread is closed,Continue here.
https://forum.videohelp.com/threads/405944-How-to-create-an-empty-blank-AVI-file-witho...nd#post2658404I think,therefore i am a hamster.
How to create an empty/blank AVI file without sound?
By tetsuro1 in forum EditingReplies: 5Last Post: 4th Jun 2022, 20:37 -
Empty or corrupt VOB file?
By Filos in forum Newbie / General discussionsReplies: 8Last Post: 17th Apr 2020, 17:05 -
Empty audio from MKV file
By ZetaStax in forum AudioReplies: 2Last Post: 2nd Aug 2019, 03:51 -
How to create a fresh date / time stamp for a DV AVI file?
By guy24s in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 7Last Post: 8th Feb 2019, 21:10 -
mystery Avi - Scratchy sound on original avi but good sound on edited wmv
By Calle001 in forum Video ConversionReplies: 11Last Post: 1st Jul 2017, 02:29
