Does anyone know if i can record from antenna or analog cable tv (ntsc) with the integrated tuner?
Results 1 to 10 of 10
Where are you going to find an NTSC analog OTA signal to record? Most stations broadcast only digital now. Most cable systems are digital only now too.
Do you have access to an old VHS deck? See if it's tuner can find anything. Probably not. -
It's highly doubtful it can still record discs or finalize discs. Most of those are dead and gone by now.
If this is an Ebay or Marketplace purchase.....you have been warned.
Many of the older Philips recorders could record both NTSC and PAL to a brand new blank disc VIA analog inputs....not the tuner. -
Do you have a multi-system TV? If not and your DVD recorder's recording system really is PAL and SECAM with no option for NTSC then you may have trouble watching your recordings on TVs made for N. America, especially if your DVD recorder has no HDMI out. Regular TVs made for N. America are not designed to display PAL video delivered via their analog connections.
Ignore list: hello_hello, tried, TechLord, Snoopy329 -
It helps to know the country when a question involves a TV broadcast system. That is one reason why location is included in VideoHelp's registration details although many do not disclose that information. Without a location, other members must guess to answer some questions or endure being asked "Why do you need to know that?".
Most TVs in Canada, Mexico, and the USA (also known as N. America) only support NTSC video via their analog connections. TVs that support PAL as well are called "multi-system TVs".Last edited by usually_quiet; 3rd Jun 2022 at 16:49. Reason: spelling
Identify this cable
By ereiamjh in forum Newbie / General discussionsReplies: 21Last Post: 20th Dec 2021, 11:19 -
Philips 3595H problem with 1 record
By Kiwidomi in forum Newbie / General discussionsReplies: 7Last Post: 3rd Jul 2021, 02:17 -
Converting NTSC->PAL Interlaced DVD Back To NTSC 24FPS???
By SegaSonic91 in forum DVD RippingReplies: 7Last Post: 2nd Oct 2020, 23:55 -
Cable TV queston.
By wake in forum Newbie / General discussionsReplies: 5Last Post: 30th Sep 2019, 03:19 -
HDMI to Coaxial ( cable) cable adapter
By zmann96 in forum Newbie / General discussionsReplies: 2Last Post: 19th Feb 2019, 15:21
