Ok, i downloaded all of the staragate sg-1 episode rips. They are AC3. I converted the first 5 without any problem. Then i started converting the rest without testing them. After the first season (21 episodes), i started to burn them to CD and i realized the one I was burning the sound didnt work. I went back and tested the otehr ones I had spent hours converting. Low and behold most of them didnt work. About 5 out of the 15 worked, and those 5 were in no particular order in my converting sequence. On all the rest, after exactly 6 minutes into the movie, the sound stopped. I am using TMPGenc to convert them. For the AC3 I raised the priority of direct show to 2. I converted the first 5 just fine. I checked to make sure the DIVX files played right and they did. I also tried using tooLame to do the audio. same problem. Then I tried using a different type. I tried SVCD instead of VCD, and the same thing happened. Does anyone know why the sound just stops after 6 minutes? Is this something wrong with the DIVX file that I am converting? Thanks in advance...
EDIT: They do in fact work in SVCD format. It is only VCD that does not work. I'll keep doing more checking..
-Nate
Try extracting the audio with besweet (tools, to your left) and converting the .ac3 audio to a stereo wav file. Then use this as the audio input to your TmpGenc conversion. This will hopefully solve your problems.
AFAIK VCD will only support stereo but VCD can suppport multicahnnel audio, though I am not sure how well TMPGenc coopes with converting to .mp2 multichannel format and then multiplexing. -
Search the forum please - this has been discussed at length - as recently as yesterday
Search for ac3 to wav conversion~~~Spidey~~~
"Gonna find my time in Heaven, cause I did my time in Hell........I wasn't looking too good, but I was feeling real well......" - The Man - Keef Riffards -
Posted below
http://forum.vcdhelp.com/viewtopic.php?t=90472
What I was referring to is Cyril's AC3 tool. in my post~~~Spidey~~~
Hey man im converting the same eps to vcd for my brother
Attempting 2 eps per one vcd(80-90minutes)
Been trying alot but tmpgenc cancels at 98% everytime i try to encode season 2 episode 1. Pissing me off. Ive tried converting the source to raw avi, right now I demux'd the audio, encoded it to vcd audio, and im trying the video seperate. if that doesnt work imma kill someone
It happens only with these SG1 eps. And get this. its not a problem at the end of the file. because I tried to encode just 3 minutes of video data before(with audio) and again at 98%(roughly) it stops. TMpgenc just locks up log just stops. Done this several times testing multiple parts of different eps
System
Athlon XP 2200+
512mbs PC2700 DDR(fasest settings)
Geforce3 ti 500
WD 120gig 8mb cache 7200 drive
WinXP Pro
Goldwave / AC3 problem
By andyellis in forum AudioReplies: 3Last Post: 29th Dec 2009, 23:27 -
Ac3 audio problem
By shrtyroc in forum Newbie / General discussionsReplies: 0Last Post: 25th Oct 2009, 12:52 -
m2v + ac3 problem?
By just in forum Newbie / General discussionsReplies: 2Last Post: 21st Oct 2008, 17:24 -
WinAvi and AC3 problem?
By love2learn in forum AudioReplies: 7Last Post: 1st Oct 2007, 02:02 -
Problem with AC3-ACM ???
By kehn in forum AudioReplies: 2Last Post: 26th Jul 2007, 23:05
