I Think im almost there
MPD
License URL
I have used EME logger for the PSSH ;
The length should be OK, a similar streaming platform (actually almost same company) uses the same system.Code: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
But the result is 5 Keys to decrypt
None of them work.
Also tried from MP4DUMP and the INIT mp4
That PSSH gives the same keys for this video
I think the result for this platform should be one key so either the PSSH or the License URL is incorrect
I cannot find any more POSTS to licensing URLs so this could be correct
Can someone give me a last push ?Perhaps the PSSH is wrong ?
Thank you
Hmm I have tried that but it did not seem to work in my XstreamCli program
Turns out, works when i use mp4decrypt
Glad I god the key part right though
SO, yes thank you for the right direction
You are decrypting the video and audio separately right ?
And then merging to 2 decrypted parts to make the complete output file ? -
Last time someone got 5 keys and coudn't decrypt, most likely means that the keys are for the lower resolutions of the videos and you need L1 or other tricks for 720p and 1080p.
He got these keys
Code:mp4decrypt --key 2df24eb4b80643aa8f6b17908327ea76:0d5d46d38ce7a6ea472c99389e44d67e mp4decrypt --key 1e61abb353394651add1e6fa0d2c9022:fc094217287d1b429e4fe1f196df78e0 mp4decrypt --key d37646893e25400fa785176e57acfde5:afae011952f077160eac09a188f5a0cb mp4decrypt --key 7bbd2d48b156452285ef5e1a3ee95a0a:047424811a1a86f68efa7719ce0efd90 mp4decrypt --key 5e2bbfa27e5e4778b9303949e79fcf0b:db769c6b2aff80e7f422ecdecd99df3c
In your MPD you have 6 KIDsyou need to check if the kids match the video kid
211ee9e4-24c8-4cb8-a58b-e209846b888b
this is the KID for the 1920x1080 version
in the MPD there's this
346p 2df24eb4-b806-43aa-8f6b-17908327ea76
416p d3764689-3e25-400f-a785-176e57acfde5
554p 7bbd2d48-b156-4522-85ef-5e1a3ee95a0a
554p 5e2bbfa2-7e5e-4778-b930-3949e79fcf0b
692p ef9e8a6c-a5bd-4a16-b00e-ff5a24538dff
692p 18df605c-bb8b-497a-86b3-bcffe60f93e6
1038p 211ee9e4-24c8-4cb8-a58b-e209846b888b
audio 1e61abb3-5339-4651-add1-e6fa0d2c9022
basically,, you dont have the keys for 692p and 1038p and you need L1 for those probably
Compare them with the keys you got. -
Good day, all - THIS IS MY FIRST POST - need direction to proper forum :-)
By TDinTX in forum Newbie / General discussionsReplies: 95Last Post: 20th Jul 2020, 14:38
