Hi there, I am new to subtitles editing, sorry, if it sounds liek a noob question.
I often need to "join - concatenate" two lines together.
[Attachment 65139 - Click to enlarge]
but it seems no keyboard shortcut to do so. Every time, I have to select two lines and right click the mouse -> browse the context menu -> click the function.
Please anyone can help, There is no way to setup my own shortcut of this command? either in MacOS , I tried but doesn't work (Maybe I did wrong)
Any ideas or suggestions are grateful, even you can recommend another subtitle app with this specific function w/ shortcut available.
Thanks a lot in advance.
Reading https://aegi.vmoe.info/docs/3.0/Options/#index6h3 and opening Aegisub, I would say:
- open: View->Options
- select: Interface->Hotkeys (on the left)
- press: the '+' next to 'Subtitle Grid' (on the right)
- select: 'Subtitle Grid', press: 'New'
- in the 'Hotkey'-column press the shortcut you want
- in the 'Command'-column press the arrow down key on your keyboard until you reach 'edit/line/join/concatenate'
- press: 'Apply', then 'OK'
Cu Selurusers currently on my ignore list: deadrats, Stears555, marcorocchini
In Aegisub, how to insert words for all selected lines? [SOLVED]
By Patapin in forum SubtitleReplies: 3Last Post: 30th Mar 2022, 04:53 -
Subtitle translation, show lines as done (aegisub)
By UserName351 in forum SubtitleReplies: 0Last Post: 29th Dec 2021, 14:50 -
Aegisub - Is it possible to create a fixed width black box in Aegisub
By netmask56 in forum SubtitleReplies: 7Last Post: 17th Nov 2019, 13:50 -
Make a 'hot key' for 'Duplicating' lines in Aegisub
By Kinderzoo in forum SubtitleReplies: 2Last Post: 14th May 2019, 05:19 -
Aegisub won't highlight lines that are too long
By 1v4n0 in forum SubtitleReplies: 3Last Post: 13th Jan 2018, 06:00
