No, they just come as separate files next to the video files
[Attachment 65129 - Click to enlarge]
~40kb audio
~1mb video
Most likely. Didn't really test.
Results 31 to 34 of 34
Can you tell me how to find the init using dev tools? Searching the word init brings me no joy?
Can you see the 3 vids i need help with?
Also unlike Joe Rogan - which is a podcast - these ones are labelled as Takeover - which is normally the Video ADs used by Spotify to torture free users..?
search for webm, the first 2 on the screenshot are the init " webm?token=Q43... = output init2.webm
the other 10452... is the video/audio "--output 2.webm"
Sorry, I don't have a (working) swedish vpn, so I don't see your videos
but I also see it when I look for init
it says video:
Format : WebM
Format version : Version 4
File size : 48.2 KiB
Writing application : https://github.com/google/shaka-packager version 90210b1-release
Writing library : libwebm-0.2.1.0
IsTruncated : Yes
FileExtension_Invalid : webm
Video
Format : VP9
Codec ID : V_VP9
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 50.000 FPS
Color space : YUV
Language : English
Default : Yes
Forced : No
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709Last edited by nimrahwt; 1st Jun 2022 at 11:06.
For me these links gave me audio.
Code:curl "https://video-fa.scdn.co/segments/v1/origins/b1acc6dba4d449dcf7a71659d3fabea2/sources/50cdede77eb854c186b8b08f55a6182d/encodings/a31236e0e07811ec91449129eb77fe82/profiles/23/inits/webm?token=2vMoi7r74w%2Fr7jkbz6uuXlBcl3snNyLdAw8wtTXrX20%3D&token_ak=st%3D1654147379%7Eexp%3D1654752179%7Eacl%3D*%2Fencodings%2Fa31236e0e07811ec91449129eb77fe82%2F*%7Ehmac%3D52a7ac3e3a77c67a7ea2bc17427ba4d3a4d36ddc4f284cd1b5924e3447488f08" --output init.webm
Code:curl "https://video-fa.scdn.co/segments/v1/origins/b1acc6dba4d449dcf7a71659d3fabea2/sources/50cdede77eb854c186b8b08f55a6182d/encodings/a31236e0e07811ec91449129eb77fe82/profiles/23/0.webm?token=2vMoi7r74w%2Fr7jkbz6uuXlBcl3snNyLdAw8wtTXrX20%3D&token_ak=st%3D1654147379%7Eexp%3D1654752179%7Eacl%3D*%2Fencodings%2Fa31236e0e07811ec91449129eb77fe82%2F*%7Ehmac%3D52a7ac3e3a77c67a7ea2bc17427ba4d3a4d36ddc4f284cd1b5924e3447488f08" --output aud1.webm
and it plays fineCode:type init.webm aud1.webm > audd.webm
Code:Format : WebM Format version : Version 4 File size : 36.2 KiB Writing application : https://github.com/google/shaka-packager version 4c870b8-release Writing library : libwebm-0.2.1.0 IsTruncated : Yes Audio ID : 1 Format : Opus Codec ID : A_OPUS Channel(s) : 2 channels Channel layout : L R Sampling rate : 48.0 kHz Compression mode : Lossy Language : English Default : Yes Forced : No
spotify ripper
By lomero in forum AudioReplies: 6Last Post: 1st Aug 2023, 15:06 -
Can't download videos
By Daveridge in forum Newbie / General discussionsReplies: 6Last Post: 4th Dec 2021, 16:12 -
Is there any video option like Spotify or Google Access?
By mikehende in forum Newbie / General discussionsReplies: 9Last Post: 24th Dec 2019, 10:44 -
Spotify video - how to do it
By kevinrm17 in forum Video Streaming DownloadingReplies: 1Last Post: 13th Apr 2019, 09:22 -
download videos
By jhone in forum Video Streaming DownloadingReplies: 1Last Post: 27th Oct 2017, 17:07
