Hey i'm trying to currently deinterlace some footage i have on my hdd. and the footage is encoded wrong.
its from itv sometimes in the late 2000s i would think. not sure if anyone can help. QTGMC and CCD seem to both not work for this occasion as well and reinterlacing and then deinterlacing it again. and topaz video enhance ai did not help either. file is attached is of the video untouched.
Results 1 to 30 of 30
You can't really deinterlace it because it's not interlaced. It was originally, but what you have is the two fields mingled together.
This is probably the result of it being resized while it was still interlaced to the progressive file you have now
It can probably be cleaned up a little but the damage is already done -
its a yt rip. so probably, idfk.
i am looking for actual help not morons that just say YEEEEP ITS SCREWED PAST OBLIVION.
bitch I KNOW. thats why i'm asking yall xD
cause maybe at least one of you will actually tell me something else i dont know. -
blur the video. it will have blending artefacts but it aint that eyehurtingi am looking for actual help not morons that just say YEEEEP ITS SCREWED PAST OBLIVION.
1. you loose detail by resizing from 576 to 480 vertical pixels. that also includes the interlacing crap and makes proper deinterlacing impossible
2. video is compressed af -
Another customer for BananaLacer.
In your case:
Code:Spline16Resize(640,240) Spline16Resize(640,480) #Deblock_QED() #Optional
That also wouldn't work both because of the compression and the fact that those interlacing stripes are not aligned
I think that should be a 16:9 video, not 4:3. 16:9 looks more correct, and the ITV label is probably sitting just inside the 4:3 safezone, which means it should be further out to the left.
They are not saying it's interlaced.Originally Posted by Voodoo -
That's wrong assumption on my sarcasm. Isn't sarcasm there obvious? Name as "BananaLacer" should be a dead giveaway, a smiley works as indication too.
I didn't want to resize to 480. My suggestion was to resize BACK to 576. And not with a resizer, but with DE-Bilinear which is made for this kind of situations, because it tries to take back a wrongly made resizing (while interlaced). If you find right parameters it is possible to deinterlace afterwards without too many artefacts.
In my opinion the clip IS truly interlaced (shot with a tv camera), and of course afterwards badly compressed. -
Filters are named Debilinear and Debicubic, they are intended to work only on upscales.
Not an opinion, the fact: This clip is NOT interlaced. -
It was interlaced 576px and then weaved into progressive, downsized and compressed to 480px. so interlaced.Not an opinion, the fact: This clip is NOT interlaced.
That's not what I meant. I said that by resizing the 576px video to 480px you lose details, that you cannot bring back by resizing the video to 576px. In this case it's interlacing. Debilliniar won't do much hereI didn't want to resize to 480. -
Sarcasm is supposed to be funnyThat's wrong assumption on my sarcasm. Isn't sarcasm there obvious?
What is the point of this statement?On an English forum you should understand English, otherwise you don't make any sense.
Yes. I thought the most likely use case of this problem
Is what this seems be, SD interlaced, resized smaller.
I tried that script you did, some months back,for that music video "Bellefire - All I want is you"
The script ran ok, but I couldn't find an obvious "good" value for the resize down
EDIT your sample looks pretty goodLast edited by davexnet; 31st May 2022 at 19:14.
Image "Swimming" when deinterlacing camcorder footage
By P-Rock in forum Video ConversionReplies: 9Last Post: 26th Jul 2020, 15:54 -
Deinterlacing & saving HD footage from pro cameras (QTGMC ffmpeg question)
By HighDeaf in forum Video ConversionReplies: 8Last Post: 23rd Mar 2020, 20:22 -
Deinterlacing
By jseo13579 in forum EditingReplies: 25Last Post: 13th Oct 2019, 16:33 -
Deinterlacing Problem - QTGMC & NTSC Footage
By hickeyguy in forum Newbie / General discussionsReplies: 50Last Post: 8th Mar 2019, 11:41 -
Capturing an Deinterlacing DV Footage is nigh impossible
By Pendell in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 12Last Post: 29th Jun 2017, 20:28
