  1. 1. "No new messages" text is invisible, under the Notifications option, possibly also new messages could be invisible, when using dark theme.
    2. When using zoom - text only 115% option in Firefox, some items are truncated.
    3. "Allowed file formats and max file size:" in the Upload files dialog are white on white background, so it's invisible, when using dark theme.
    4. When uploading a file, some text message is shown for a moment, background is yellow, text is white, so it's almost unreadable, when using dark theme.
    5. Favicon is missing at any site with the program, e.g. https://www.videohelp.com/software/PotPlayer . FIXED
    6. "Hot" color to highlight the item use dark red color on dark grey background, it's not good readable, when using dark theme.
    Image Attached Images
    The favicon is same for the entire site,
    https://www.videohelp.com/favicon.ico
    Do you want favicons for every program?
    I will try fix the other issues.
    Thanks for the bug report.
  3. Thanks.
    There is no favicon for the programs, default icon would be enough.
    Originally Posted by Dreamer View Post
    Thanks.
    Strange. It works fine in Chrome and Edge. And online favicons checkers: https://realfavicongenerator.net/favicon_checker?protocol=https&site=www.videohelp.com...r#.Yppy4nZBxqI
  5. I'm a MEGA Super Moderator Baldrick's Avatar
    Found the favicon bug.
  6. #5 favicon issue is fixed, thanks.
  7. 7. Some smilies look not good on dark background.
