Hello
I have some MP4 videos (1080P) i want to put on a disc. However i need to change the video codec from H.264 to MPEG-4 as the disc will be played on a Blu-Ray player. I will using Handbrake (Unless anyone knows of a better software) to do this. Anyway, would anyone know the best Handbrake settings to get the same quality as the original source?
I did a conversion before posting the outcome was quite fragmented and the video was half the size of the original source using these setting - Framerate (FPS): Same as source - Peak Framerate - Quality: Constant Quality 22 - Encoder Preset - Fast . I think should have change the latter to slow.
h.264 is an MPEG 4 codec -- part 10 of the spec. Most Blu-ray players that can play media files can play h.264 in mp4. Do you mean your player only plays a MPEG 4 part 2 (Xvid/Divx) codecs?
https://en.wikipedia.org/wiki/H.264/MPEG-4_AVC
https://en.wikipedia.org/wiki/MPEG-4_Part_2
Anyway, if you want larger files (and presumably better quality) lower the Constant Quality setting. Changing the preset from Fast to Slow may not make much difference in the size. But the image quality should get a little better. I recommend you also specify Constant Frame Rate. -
Thanks jagabo for reply.
Yes, i think you could right be without checking as its a friends player.Do you mean your player only plays a MPEG 4 part 2 (Xvid/Divx) codecs?
Handbreak cropping issue
By iKron in forum Video ConversionReplies: 4Last Post: 8th May 2022, 11:12 -
Why does Handbreak need TS info file?
By tom z in forum Video ConversionReplies: 9Last Post: 29th Nov 2021, 04:48 -
How to remove banding from a animation video in handbreak
By UzuPower in forum Video ConversionReplies: 0Last Post: 22nd May 2020, 01:42 -
How to stop adding color effect using handbreak
By iKron in forum Newbie / General discussionsReplies: 4Last Post: 2nd Nov 2018, 11:03 -
MKV not working in Handbreak
By Brian7k in forum DVD RippingReplies: 0Last Post: 22nd Apr 2018, 16:13
