recently i came across some video files that can only play by a password and the format was .gem. any way to convert those to normal formats? I can post link after some time
Results 1 to 14 of 14
@PUOPUO, isn't this request the same as this one?
Code:https://forum.videohelp.com/threads/406222-how-to-extract-mp4-from-gem-file
Kindly post your link to the post started by shakila21I can post link after some time -
thank you for your reply. yes the mentioned link is the topic I started. but I saw your topic in the history and I wanted to asked you in a private message to see if you found a way to overcome this issue. but the system said sending private message to you is not permitted by you. thanks anyway.
Thanks for your reply. Is it possible to share it here with other people so that everyone could remove the key?
I need help decrypt movie files (starzplay) , files included !
By Dazzle Cat in forum Video Streaming DownloadingReplies: 1Last Post: 1st Oct 2020, 19:29 -
How do i convert .srt files to .odt files?
By jooj in forum SubtitleReplies: 2Last Post: 25th Dec 2019, 20:32 -
Batch combining multiple audio files with same picture to create mp4 files
By MD_89 in forum AudioReplies: 25Last Post: 1st Dec 2018, 23:29 -
AVI Files Smaller Than WMV Files
By tutorpros in forum Newbie / General discussionsReplies: 51Last Post: 23rd Dec 2017, 18:44 -
Need help with Mplayer to play mov files which reference to external files
By Selur in forum Newbie / General discussionsReplies: 0Last Post: 2nd Dec 2017, 13:21
