  1. how do you add a codec to you to your computer because i need to know how? thanks
  2. You install it.
    Which codec are you wanting to install? That would make helping you a little easier.
  3. No Longer Mod tgpo's Avatar
    Feb 2002
    The South Side
    yeah, the installer should add the means for export.
  4. You would probly want to get divx 5.0.1 for your video codec you can get it at http://download.com.com/3000-2194-9675928.html?tag=lst-0-1
    and you would probly want radium mp3 codec for audio codec you can get that at http://www.riphelp.com/downloads/radium_codec.html
    I went to look for myself, if I get back before I return, Keep me here.
  5. my last question is will realone work better than real player or does it matter? and will wmp 7.0 work better than any other old version of it or does it matter? thanks
  6. No Longer Mod tgpo's Avatar
    Feb 2002
    The South Side
    I've used Realone and hate it. The second I would load it up it crashes and says it must be restarted. Once restarted it crashes again.. It's one big loop. As for WMP I'd go for the newest one.
