  1. HumanViewer
    May 2022
    Finnish
    RT, I want to change the pix_fmt and colorspace of a video, from yuv420p, bt709 -> yuv420p10le, bt2020;
    But it looks like a little weird, orange -> red.
    I'm not a new ffmpeger, here is my command:
    ffmpeg -hide_banner -y -i INPUT -map 0:v -c:v copy -pix_fmt yuv420p10le -colorspace bt2020nc -color_trc smpte2084 -color_primaries bt2020 OUTPUT
    Can somebody tell me why?
    thank you so much!
    orange.mp4
    test video 0
    Format/String                    : MPEG-4
    Format_Profile                   : Base Media
    CodecID/String                   : isom (isom/av01/iso2/mp41)
    FileSize/String                  : 3.73 KiB
    Duration/String                  : 5s 0ms
    OverallBitRate/String            : 6107 bps
    Encoded_Application/String       : Lavf59.17.100
    Video
    ID/String                        : 1
    Format/String                    : AV1
    Format/Info                      : AOMedia Video 1
    Format_Profile                   : Main@L3.1
    CodecID                          : av01
    BitRate/String                   : 3928 bps
    Width/String                     : 1280 pixel
    Height/String                    : 720 pixel
    DisplayAspectRatio/String        : 16:9
    FrameRate_Mode/String            : CFR
    FrameRate/String                 : 25.000 fps
    ColorSpace                       : YUV
    ChromaSubsampling/String         : 4:2:0
    BitDepth/String                  : 8 bit
    ScanType/String                  : Progressive
    Bits-(Pixel*Frame)               : 0.000
    StreamSize/String                : 2.40 KiB (64%)
    colour_range                     : Limited
    colour_primaries                 : BT.709
    transfer_characteristics         : BT.709
    matrix_coefficients              : BT.709
    CodecConfigurationBox            : av1C
    https://files.videohelp.com/u/302682/orange.mp4
    red.mp4
    General
    CompleteName                     : E:\local_workspace\go_test_slice\video\test_sapce\ts_3\red.mp4
    OverallBitRate/String            : 6106 bps
    Video
    ID/String                        : 1
    Format/String                    : AV1
    CodecID                          : av01
    BitRate/String                   : 3926 bps
    ColorSpace                       : YUV
    BitDepth/String                  : 10 bit
    colour_primaries                 : BT.2020
    transfer_characteristics         : PQ
    matrix_coefficients              : BT.2020 non-constant
    https://files.videohelp.com/u/302682/red.mp4
  2. Can somebody tell me why?
    You are just changing the flags on the video you are not doing any conversion there.
    You would need to reencode and use additionally something like colormatrix https://www.ffmpeg.org/ffmpeg-all.html#colormatrix to convert something.
    Side note: What reall buffels me is that the bit depth changed, '-c:v copy' should have prevented that,..
  3. [QUOTE=Selur;2658207]
  4. @ProWo: I know, but unless it only changed some flag it should not change the color space,...
  5. Or use zscale, to change matrix, transfer and primaries; with -c:v something other than copy
    -vf zscale=min=709:m=2020_ncl:tin=709:t=smpte2084:pin=709:p=2020,format=yuv420p10le -c:v something
  6. HumanViewer
    May 2022
    Finnish
    thanks for reply, this make me notice the color matrix transform.
