I have seen a lot of videos that look yellow, some nude bathroom scene, most look to be a result of lighting or camera settings.
Is there a simple white balance edit that would go some way to correct?
Second question, how do you reduce red and green or increase blue to correct a cast?
Results 1 to 11 of 11
Try virtualdub2. You'll find some color correction tools in
the filters -
I want to keep the file original, some mp4, just found others are mpg.
virtual dub would only be good if I am saving to lagarith between process?
Here is what I have found so far, just not sure if the Shadows/Midtones/Highlights options should be used for the task, or otherwise edited to work.
default 0.0, seems pretty simple to use.
Any ideas on how to aproach it?
Code:$ ffmpeg -i input.mp4 -vf "colorbalance=gs=.5:bh=1" -pix_fmt yuv420p output.mp4
Code:colorbalance Indicates the color balance filter name rs, gs, bs Indicates adjustments to red, green and blue shadows or darkest pixels (1.0 to -1.0 with default 0.0) rm, gm, bm Indicates adjustments to red, green and blue midtones or medium pixels (1.0 to -1.0 with default 0.0) rh, gh, bh Indicates adjustments to red, green and blue highlights or brightest pixels (1.0 to -1.0 with default 0.0) pl Indicates preserve lightness when changing color balance (1.0 to -1.0 with default 0.0)
So for the FFMPEG Users, here is the next snippet I found:
Quote from https://www.dpreview.com/forums/post/61575417
Code:Maybe you can use the eq filter? ("Set brightness, contrast, saturation and... gamma") For instance, to reduce blue cast and increase color saturation, call video filter (-vf) with eq items, while copying the audio track (-c:a). ffmpeg -i orig.mp4 -vf eq=gamma_b=0.8:saturation=1.6 -c:a copy PitNew.mp4 -
Hey, I use FFmpeg too. I think you'll just have to try some of these filters and see what gets you close
to what you want. There are many possibilities in the FFmpeg filter reference doc.
Were these videos taken with your own camera, presumably with lighting issues? -
Can you just use the r,g,b commands as needed?
This is probable wrong, I strung together bits from internet!
Code:ffmpeg -i IN.mp4 -vf eq=gamma_r=0.8:gamma_g=0.8 -c:a copy OUT.mp4 Or: ffmpeg -i IN.mp4 -vf eq=gamma_b=1.2 -c:a copy OUT.mp4
The value must be a float value in range 0.1 to 10.0. The default value is “1”.
gamma=1:
gamma_r=1:
gamma_g=1:
gamma_b=1:
gamma_weight=1
I am just interested in the correct code.
ffmpeg is very fast and simple to look at results and re-adjust
Edit: Think the code will be correct now, can gamma_weight be used so the other gamma_(Letter) edits have reduced effect, like more resolution?Last edited by Tom4; 27th May 2022 at 00:17.
The video in bathroom is porn, wish I did take with camera LOL.
I have the complete set of codes for ffmpeg and every UI that could be found online.
Love the programs power and use
First attempt to correct yellow/lighting/cast issue worked perfect
First really good solution:
When I say perfect, like Just wow and that simpleCode:ffmpeg -i IN.mp4 -vf eq=gamma_r=0.8:gamma_g=0.8 -c:a copy OUT.mp4
Examples of manupilation of video colors with ffmpeg - eq (4) - gamma
https://www.youtube.com/watch?v=4Ko38xnvN7s
Playlist https://www.youtube.com/playlist?list=PLT89WYRFupd6FLlbJWInTrYa0lEwAeJ4uLast edited by Tom4; 27th May 2022 at 00:36.
Trouble with white balance in Premiere
By miguelmorin in forum EditingReplies: 2Last Post: 11th Jan 2021, 07:52 -
What are the FFMPEG settings codes for Ut video in OBS?
By Truthler in forum Capturing and VCRReplies: 1Last Post: 2nd Dec 2020, 10:09 -
Recoding huge DVD+video archive to HEVC - advice on ffmpeg settings + Card?
By STilez in forum Video ConversionReplies: 22Last Post: 13th Oct 2019, 12:58 -
A proper frame by frame way to white balance ?
By greatfinders in forum RestorationReplies: 3Last Post: 2nd May 2018, 17:53 -
color correction for white balance wrong?
By marcorocchini in forum Newbie / General discussionsReplies: 7Last Post: 24th Jul 2017, 22:22
