Hello everyone. This has been my go to plugin for years, however recently I built a new system and installed Windows 11. Copied my plugins folder but GrainFactory3 refuses to work.
[Attachment 64995 - Click to enlarge]
This is basically it. I did upgrade MaskTools2, it didn't solve anything. In fact the mt_merge was mt_lut in the same error before I installed one of the previous versions
Any help? Thanks!
Post result of "AVSMeter.exe -avsinfo".
Thanks for the suggestion. According to Avsmeter I removed the redundant old plugins, installed FFTV and made sure the Runtime Redistributables are installed.
Still, no luck.
[Attachment 65026 - Click to enlarge]
[Attachment 65028 - Click to enlarge] -
Screen is only up to "D", just paste whole text.
Also: What does your GrainFactory3.avsi look like?
In http://avisynth.nl/images/GrainFactory3.avsi mt_merge-call isn't in line 122,...users currently on my ignore list: deadrats, Stears555, marcorocchini -
So, I gave up and solved it by wiping the plugins folder, reinstalling Avisynth+, switching to 64 bit versions of that plus Virtuadub2 and starting to gather the important ones from scratch. Stuff like QTGMC and GrainFactory3 work now. I think it was the best solution anyway because I had lots of crap there, things I downloaded from at least a decade ago. Going through all that would probably cause a headache. Sorry for wasting your time, but at least I learned about Avsmeter
[Attachment 65029 - Click to enlarge] -
HDVSplit transfer failure
By Ferggue in forum Capturing and VCRReplies: 4Last Post: 9th Dec 2021, 20:55 -
Avisynth Open Failure: (Please Help)
By EJN992 in forum RestorationReplies: 1Last Post: 2nd Feb 2021, 09:06 -
Avisynth/VirtualDub2 open failure Script error
By Pixl_talian in forum Newbie / General discussionsReplies: 29Last Post: 2nd Aug 2020, 17:10 -
avisynth open failure:FFVideoSource: Video codec not found using vafe
By NightBreaker in forum Video ConversionReplies: 1Last Post: 7th May 2018, 09:26 -
Failure to download 1080p with youtube-dl
By nzhd in forum Video Streaming DownloadingReplies: 8Last Post: 12th Jun 2017, 04:43
