Hi There:
I'm a little new to the whole making VCD's bit, but I have managed to follow TGPO's latest guide to making VCD's on a Mac.
I can rip the DVD!
I can convert the .ac3 file to .aiff!
I can convert the .m2v file to .mov!
I can for the most part line up the .mov file with the .aiff file!
But I guess that's all the easy stuff!
But where I'm having a problem is converting the .mov file into a Toast Ready VCD File, because I don't have that option when I export the file through QuickTime Pro (Even Though I Have Both Programs Loaded On My Computer). And when I try to drag my .mov file to the Toast screen I get a -1138 or something like that error message.
I am however running Toast 4 Deluxe with the most current updates. Should I upgrade to Toast Titanium?? Would that make the difference??
Any suggestions would be great!
Thanks For The Help And The Guide TGPO!
Coaster Boy!
Yes, you'll need the Toast Ti. And you'll be able to export it to MPEG1 format.
Toast Titanium is needed. It will add an extention to allow Quicktime Pro to export Video Cds.
Ah!!!!!
That makes all the sense in the world! Thanks for the help guys and gals!!!!!
Coaster Boy
Making a VCD to send to the Philippines
By StrikerZERO in forum Authoring (VCD/SVCD)Replies: 17Last Post: 7th Dec 2010, 09:11 -
Problem: Final Cut Pro, taking a 24p HD Blu-Ray and making a DVD with Toast
By apollo1980 in forum Authoring (DVD)Replies: 1Last Post: 22nd Apr 2010, 09:03 -
Making VCD Copy
By audiophile in forum Authoring (VCD/SVCD)Replies: 5Last Post: 18th Sep 2007, 07:20 -
General Guidance and Hardware req. for making VCD with Digital Camera
By dpilot83 in forum Newbie / General discussionsReplies: 4Last Post: 11th Jun 2007, 05:53 -
Which steps should I use?
By Belfour in forum Newbie / General discussionsReplies: 5Last Post: 5th Jun 2007, 09:33
