I have a .srt file. The italic lines are tagged with <i>xxxx</i>.
But the software I use to create a DVD (TMPGEncAuthoringWorks4) doesn't recognize the tags and shows the lines with the tags, without doing the text italic.
And the subtitle software I use (Subtitle Edit) doesn't have a function were I can remove the tags and convert the lines into italic.
I can find and delete all tags but not convert the lines into plain italic without the tags.
So is there a way to:
1. Remove all the italic tags from all lines that are affected.
2. Convert the text in those lines to italic directly without any tags.
There are many lines that are affected so doing it line by line is not practically possible.
I want some batch function that can do it.
have a look here
You have to replace <i>xxxx</i> with it's equivalent for TMPGEncAuthoringWorks4 -
Use this to create a subtitle with italics.
Upon completion, open the newly created subtitle and look at how italics are handled. Change your file likewise. -
SRT subtitles are plain ASCII text. There are no italics.
https://computersciencewiki.org/index.php/ASCII
Don't even expect the extended characters to render properly as subtitles. -
My thoughts too. I've always understood that these tags are just a trigger for a player or text-to-image-handler to create italic text in the image.
TBH it's been ages since I worked with video-dvd subtitles, but isn't the format VobSub (sub/idx)? Unless I'm missing something here, SE can export srt to VobSub while honouring italic tags. -
The thing is, the use of HTML tags in SRT subtitles are not part of the official SRT format/specs, so support in any program for editing and converting them may be minimal (if any) and with no standard for interpreting them, programs may well interpret them in different and unexpected ways.
I'd wonder if it would be a better idea to convert the SRT-with-HTML to a format that actually does properly support styles and formatting without kludges, like, say, SSA/ASS, but I don't know how easy it would be to convert from those formats to vobsub.If cameras add ten pounds, why would people want to eat them? -
I'm still trying to understand how do those people manage to mess subtitles like that
How do I remove these vertical lines?
By coolgit in forum RestorationReplies: 23Last Post: 3rd Aug 2021, 13:35 -
How to remove horizontal lines
By ziggy1971 in forum Video ConversionReplies: 17Last Post: 26th Jan 2021, 08:49 -
How to add the same tags to multiple lines at the same time?
By Malls Baloney in forum SubtitleReplies: 0Last Post: 23rd Sep 2020, 03:57 -
.sup files missing lines when OCRing or editing directly
By sullivan003 in forum SubtitleReplies: 0Last Post: 18th Apr 2020, 05:18 -
SubtitleEdit - how to remove tags <span style>
By [ss]vegeta in forum SubtitleReplies: 7Last Post: 5th Jun 2019, 23:15
